Cottonland Wrenching Sessions
MSU - Arkansas. Gotta see about that first. I know, I know!!!
Amanda says we're going to the State vs Arkansas game. Probably the only game I'll see this year. Sorry I'll miss it.
What time is the game?
you know I will have it on....
Houston @ USM that day, yall have fun.
Why would I watch it on TV if I have tickets?
Why would you miss a Cottonland Wrenching session?!
its like the effen Catalina Wine Mixer!
name that movie.
Can I change my oil in the driveway? I don't have a pan.
I don't think I have to worry about YOU changing your oil.
I need to change the erl in the Tundra...
I would not do high clearance lower control arms. They help get your tires up a vertical face. Without the control arm your tire hits flush and needs to climb 100% of ledge or rock and not 50%.
The way to go with those rears is to get some made out of 41300 Chrome Moly and have them heat treated.
4130 Heat Treated Links!! - Pirate4x4.Com Bulletin Board
Stronger than solid....
pm this guy from Heretice 4x4 he said 4130 heat treated lower control arms $210 a pair!
1.75 OD .188 wall 7/8 inserts
I am not sure what the price difference would be between 1.25 inserts and 7/8.
Let me know Lenny might order a pair for Deb's truck.
Is there a body man in da house.....need one!
remove em. less to get in the way. or run some tube fenders.
if you are feeling saucy we can fire up the tubing bender and give it a go.
I have bendtech pro, so we can design on computer first..
Hot Damn!
Who:
What:
Where:
When:
I wish I could bring my junk, I got a rear axle to switch out now!
Who:
What:
Where:
When:
borrow a trailer and haul lorena big butt up here. we can swap that sucker out in no time.
All right Saturday November 20, 2010 at my house.
I will change the dreaded Pesky Heater Hose on my 80.
Might as well flush and refill radiator and change out thermostat. for starters...
Hopefully Mark will show up with his wild west fab hi clearance lower control arms so I can make a jig for it. You coming Mark?
Samurai steer box is back on and frame is reinforced, so I will be installing new rock assault pump, large reservoir and ram assist hopefully before nov 20 so I can make some more room.
My spare radiator for the samurai is leaking :mad: so I have to fix that before I can put it all back together. will make it easier to swap pump in with rad outa there anyway.
__
