Well all the flares came off, with the exception of the rearmost 2. all they lack is just the removal. the door set of flares didnt cooperate, nor did the front drivers flare... i finally decided the hell with it and went to town... flares are off now, and the sheetmetal still looks good, so all is well.
Body lift is also installed. all 10 pucks are in and all 10 bolts are tight. everything is double nutted, with nylock nuts and grade 8 hardware. lower radiator brackets are modified and almost installed (they're in there, just not tightened up). The upper radiator mount is causing some serious headscratching.... im not sure exactly what im going to do yet. i cant figure out how to drill out the new holes without doing some serious disassembly.
I also spent about 2 hours figuring out the wiring schematic for the additions, and then figuring out what parts i needed and where its all going to go. the i get out to the truck and im thinking thats not going to work. The wiring is all still good, now i just need to figure out where everything is going to go. then comes figuring out where the wiring is going to be routed... too much stuff goin in... im seriously wonderin about alternator capacity issues.
I also determined that the place I want to buy the switches from to control the electronics is being REALLY slow at returning emails. IF anyone knows of a good place to get switches that are LED lit with nice labeling like winch, air, rock lights and so on lemme know. And I'm thinking about using some LED lights that autozone has for rock lights... curious if anyone has ever tried them. according to my sources they're only about 14 bucks and decently bright, so i fugure its worth spending the 14 bucks and investigating.
For those that are curious, my wiring nitemare involves the following...
1. Front and rear winch with in cab controls.
2. On board air with pressure switch and in cab master switch to start the system
3. Rock lights, 2 stage. first stage will be just tires, second stage will be tires, axles, and full undercarriage.
4. Front flood lights setup to turn on with the master in cab switch, or be off at all times, or turn on with the bright lights.
5. Rear flood lights to do the same as the front floods except have the ability to come on when in reverse. both these sets of lights will be ran off of seperate DPDT switches where it will be ForcedOn-Off-OnWhenPrompted where the OnWhenPrompted means put in reverse or high beams on. Ought to be some cool stuff.
