Hey guys, trying to figure out what the problem is with my 2005 LC. just got it from my inlaws a few months ago and noticed that the coolant was low in the reservoir. not empty, but at the low mark. filled it up and noticed that the level dropped again. started looking and found coolant on the bottom bolts of the radiator and saw no other coolant anywhere. the radiator had 231,000 mi on her so I replaced it and it solved the leaking radiator problem. but im still losing coolant somewhere. im not seeing it on the ground, or on any hoses which worries me, but im also not seeing any white smoke out of the tailpipe or any issues idling. the oil looks pristine and the radiator cap is brand new so im not sure where it can be going. the coolant in the radiator is still a perfect clear red color and no contaminants to be found. where else should I be looking? I figure my next step is getting it compression tested. it has overheated once as far as I know. the heater T's failed going down the interstate. but that was maybe 50k miles ago?
Oh also shes not overheating at all. the highest ive seen is 195ish on the OBD2 reader.
Thanks for your time.
