I've had my 98 LC since February this year. The past few months, I've been checking the fluid level on my car in the mornings once a month. Once a month, I've been having to refill the reservoir slightly about 1-2oz, or less back up to the full line. But this morning, I was a bit lazy and drove to work without refilling it. But when I got to work, the reservoir was well over the full line. Is this normal?
My radiator is always full. Car does not overheat, I've even did a pressure test in the cooling system with no leaks anywhere. Below are the details on what has been done to the car including mileage. Thanks in advance.
1998 LC, 146K (Currently, bought it at 140K)
112K, Timing Belt and Water Pump was changed by PO
Under my ownership since Feb, past 5K miles
Heater Tees
Thermostat
Radiator Cap
I also refilled about 1 gallon of radiator after changing out the thermostat.
Heater Tees
Thermostat
Radiator Cap
