yep.. I've just replaced the whole lot.. the only thing I havent replaced is the heater core (fine for now, fingers crossed)I've come to learn with my 1FZ that I can't keep up with replacing enough cooling system parts.
What's up Pappi. Good to hear from you.You should replace the head gasket along with overhauling the head (in my opinion). With those amount of miles, it’s about time …….
Dean did this big job last year, all new cooling components too !
I picked up this 450 in 2014. Since that time ALL rubber/soft parts have been replaced sequentially with OEM right down to the door gaskets and window regulator channel fillers.
New OEM radiator in 2016 along with a new modified fan clutch. Has never run hot even when pulling my 416 over the hills on RT80 through Nevada last June in 103F ambient. I think the hottest I've seen is 210F which made me uncomfortable.
I'm waiting for the snow/rain to stop around here to do some more diagnostics before jumping in. I don't have a useable garage, so I might have to find a place/person to do this for me if it comes to that. She's my daily driver so it can't be down for too long.
just out of curiosity, was the coolant loss from the overflow or the radiator?For sure your attention to detail as well as your ow approach makes your LX450 unique and one of a kind !
As you know, Dean bought his Lexus with a rebuilt motor. PO blew the head gasket by bursting the Pesky hose on the highway. He also told me the head was so warped that couldn’t be rebuilt so bought a Chinese one….. once we got it, that head always overheated in traffic and hot summers until we noticed the same, there was a slight coolant loss that we couldn’t figure it out until the day gasket called it quits. Luckily, it by passed the oil galley’s not affecting the internals. I had an extra Used OEM head I sent out and probably your best bet to approach it this way, get everything ready to minimise time…..
Deans truck now perform way better than ever….
I will parting out another 80 soon if you need a motor, just saying …..
Overflow, but it wouldn’t matter which one is losing/evaporating as both are constantly communicating (high and low temps)just out of curiosity, was the coolant loss from the overflow or the radiator?
But it looks like in this case the system is completely closed with no leak as the extra volume in the overflow corresponds exactly to the volume initially drawn out from the radiator.I had the same thing happen to me and it ended up being the down spout hose return into the radiator on the passenger side. On my 3FE there is a metal coupler between the bottom hose and the top hose that comes out of the thermostat housing on the way down. Its attached (the coupler) right behind the PS pump area to the water pump housing, I think. There were two pipe clamps in there that were SUPER hard to get to, and both were leaking JUST slightly and vaporing on the way out. That's why it took me a long time to find them. It only happened while I was driving and vaporized because it was high enough pressure to spray out in a super thin line from the fittings. I finally ended up finding the white deposits from the fluid on the frame which directed me to find them. If not for that proof, I would have never found it. If I can take some photos for you tomorrow, I will put them up here. Might be something to check at least.
Get rid of those Home Depot worm drive hose clamps.Well in any case, here is what I'm dealing with. Found today that it is leaking again. This is where mine comes from.
^this. A dab of Vaseline on the hose nipple will repay you miles down the road.
