Coolant in the floor *pic*
Bend, Oregon
How is this happening?
I tore out the interior yesterday and found this. The passenger floorboard was pretty wet from the coolant. I am assuming there is a hose running through the firewall that is to blame for this mofo. Any thoughts?
HEATER CORE :bang:
It's the heater core leaking. No hoses inside the cabin. Heater hoses attach at the firewall. You're going to have to remove the heater box and replace or fix the core.
#26 in the pic.
That's a bummer. I will be tearing into the dash later this weekend and checking things out. Thanks!
Yeah, that stinks. Sorry man but they are right.
Incidentally, price of a new heater core will floor you (no pun) ... You may want to source a good used one and clean and flush it, or take it to a rad shop before you remove your old one. Just my .00002 where's the cent symbol on the keyboard ??
Does anyone know the price of a new (Toyota brand) heater core? (I'll be sure to be sitting down when the answer is posted.)
You are right; there is no cents symbol on the keyboard anymore. It used to be shift of 6 or something . . .
Will I neccesarily need a new heater core? Can't I just fix the leak? It may be leaking from one of the hoses.
Either way, the truck came with a spare heater core. Hopefully one of them is repairable.
Edit: Just read through a couple of the replacement threads. You guys should try replacing a heater core in an A4. The cruiser looks like a cake walk. :)
New core is North of 3 bills... Really. SOR wants $359 .... Merry Christmas.
Yeah, if the old core is repairable, that's fine. But I'd take it to a Radiator shop to get it pressure tested, if you don't have a way to test it yourself. I wouldn't want to have to take it out twice.
Came with a spare heater? Sounds like the PO knew it was bad. It is a serious pain in the ass to swap the heater core. Defiantly get your "spare" cleaned and pressure tested before you do the install. That is a job you only want to do once.
Dynosoar:zilla:
I bought a heater core from JT Outfitters for about $120. It dropped right in. I think it's aluminum compared to the OEM copper one, though.
I only replaced mine because I was redoing the wiring and insulation under the dash and I didn't want to get under there for another 20 years. Otherwise, the heater core is in great shape. Let me know if you want it.
Yep-That's too bad. Do what ever you need to do to start with a good core and new "o" rings for the pipes. Ducks had quite a time with his if I remember correctly.
