For Sale Columbus, OH: 1994 Land Cruiser (2 Viewers)
Content may include affiliate links. Please see terms for details.
Year
1994
  1. 80 Series
Mileage
150000
Color
White
1994 Toyota Land Cruiser
$7999 or best offer
Full time 4wd
4.5l Engine
Automatic
Runs, drives and rides smooth
The good:
- Clean interior / seats
- New front / rear calipers / discs / pads
- New front wheel bearings
- New front knuckle seals / gaskets / grease
- New front gear oil
- New front sway bar bushings
- New front / rear u-joints
- New radiator / hoses
- New power steering pump
- Rebuilt power steering gearbox
- New water pump
- New belts
- Newer air conditioner
- New transmission filer / fluid
- New master brake cylinder
- New plugs / wires / distributor cap / rotor
- New air filter
- New valve cover gasket
- New spark plug oil seals
- New distributer oil seal
- New quick change battery terminals
- New bluetooth stereo
- New floor mats
- Newer tires
- New hood supports
- Resealed upper and lower oil pans
- Lexus engine replacement
- All electric windows / sunroof work
The bad:
- While I installed a newer A/C, I never got around to charging system
- Rear heater disconnected (front works)
- Wheels are painted but may be stripped to original aluminum by time of sale
- The engine was replaced by a previous owner and runs good but I have no record of the engine mileage (150k is a best guess only). The truck itself has ~280k miles
- Small oil drip on front bottom of motor
- Never have had an issue, but ABS dash light is on and is typical of these trucks
The ugly:
- Body paint has some flaws
- The driver's rear rocker panel has rusted through. Was planning to weld on some rock sliders
- The rear lift gate has a rusted hole in it but have a replacement liftgate / tailgate that goes with the truck. Was going to paint them (and the body flaws) and install but ran out of warm weather.
- Parts of the front wheel wells inside the engine compartment are rusted. Visible only within engine compartment
Ohio
2022.12.17 Update:
- Replaced front cranshaft seal
- Replaced oil pump cover o-ring
Oil leaks are gone!
Texas
looking for an 80 about like this... I'm a southerner so I'm concerned about the extent of rust damage - assuming this has been a northern car all it's life? A bunch more pics all around - in/out/under and roof would be really helpful.
Ohio
2023.02.16 Update
I just finished putting a complete new exhaust on the truck including both manifolds, catalytic converters and muffler.
While I had the manifolds off, I also replaced all the seals at the oil cooler and put in a new thermostat.
The new exhaust made a huge difference. While it ran good before, it runs really good now.
Because the exhaust cost $1,000 in parts alone, I will be looking for closer to $9k now
