BOSCH
I am having the same problem code 25 sometimes code 26 and running like crap. I have a 93 and tested the VAF and got the same readings as you on the 20k scale 3.02 closed and 2.91 open basically the same, no difference open or closed. What was your end result, did you get this fixed?The manual says that when moving the gate the resistance should measure 20 ohms to 1200 ohms. But moving the gate does not change the value and the entire time it reads 2800 ohms... Can the VAF be repaired anyway are there internal components that I can replace or does the VAF need to be replaced. And if so does anybody know a good source or aftermarket that's it is cheaper than the Toyota replacement they are quoting about 900 dollars
I'm metering the two right terminals.anyway, the VAF works basically under the same principle as a volume knob on a stereo. If you've damaged it, chances are there is no repairing it.
But there are 6 contacts in there, and the FSM only refers to the three closest the engine. So i wonder if you are reading the wrong contacts.
OK I'll check when I get home. I Was kinda thinking it might be a typo because danman78 is getting the same readings as me open or closed on the two terminals in FSM between 2800-3000 ohms.Ahhhhh, therein lies the rub.
On page EG-292, Air Flow Meter Inspection - the diagram shows VS as the right-most terminal and E2 right next to it.
But back on page EG-290 - On Vehicle Inspection - it shows E2 and VS as terminals 4 and 5 of 6, with terminal 6 - on the far right - being THA.
See what happens when you test terminals 4 and 5 instead of 5 and 6.
Tho it may be blasphemy to say this, I believe there may be an error in the FSM.
I see now in the FSM what Slim is talking about, I belive its that way in the 93 and 94 FSM I'll recheck it using the other terminals. I checked my PAIR valve by applying vacume to the valve and then blowing through the intake and it passed, did you do anything more than that? Along with code 25 was your the truck running crappy, and did you have any other codes? (I had a 24 & 26 to) I'm in a rush to get this fixed because it needs to be inspected by months end, and I know it will fail plus the cats are glowing cherry red just driving around town not good!You guys are correct, I found the same error in my 94 FSM when I was troubleshooting the same exact code. My situation was a bit more involved. First, my PAIR valve was stuck open, essentially flooding the O2 sensors with intake air-hence the detection of a lean condition. So I deleted the Pair Valve alltogether. Put block off plates on the exhaust and removed the valve and silencer. Later on found that my VAF was also going bad so I replaced that with a low mileage used one, no way I would pay the 1100 for a new one. The truck passed Washington State Smog tests with flying colors without the PAIR system FYI. Blocking the PAIR for diagnostic purposes would be easy enough as well. It took me all of 10 minutes to make plates with a drill press, grinder, and band saw.
