My idle is stumbling and low and when I dive the truck shutters with poor power. I do have a snorkle I'll check the silencer for the PAIR to.The truck was running poorly, stumbling idle and lack of power. The idle would smooth out as I gave it gas. If your cats are glowing red, there is a very high possibility that you are getting too much o2 back there which would make it burn hotter. and really, the only culprits that I can think of that would introduce a lean mixture would be your VAF, PAIR, or a crack in the intake tube beyond the VAF. One thing that was happening when my PAIR was failed open that you could check really easily:
The silencer can that hangs off of the main Air intake Filter housing, was filling full of condensation. At first I thought it might be a by product of Seattle Snorkel ownership, but it turns out that with the PAIR valve constantly open, the Hot Exhaust gas interacting with the cool intake air was resulting in a ton of condensation gathered up in that little silencer can right off the intake. I would check that for any water, and would feel confident in saying that if you find any, your PAIR could be open more than it should be, (this could also be caused by whatever component tells the PAIR to open up failing as well.) Probably not your issue, but something more to check.
