Actually it wouldn't make a great missle, since the boil-off pressure of CO2 is only about 300psi, so that's the most pressure you'll ever get out of the bottle...unless you were to heat it up. Nothing like a O2 tank or scuba tank, which are actually at 3000 psi, and you wack a nozzle off there and you better start praying! The difference is CO2 like Propane (LPG) turns to liquid at about 300 psi, so in the bottle it's a liquid, not a gas anymore. This is why propane tanks are not really beefy tanks, not alot of pressure to deal with.woody said:I'd be VERY likely to bust off that valve and make a missle....
mabrodis said:Actually it wouldn't make a great missle, since the boil-off pressure of CO2 is only about 300psi, so that's the most pressure you'll ever get out of the bottle...unless you were to heat it up. ]
I’d like to chime in on this one...I'm not sure everyone has accurate info regarding Liquid Co2. Co2 has a boiling point of -200 degrees, and will continue to boil until either the temp drops below -200 degrees, or the atmospheric pressure reaches over1000psi. Liquid Co2 tanks do not have the same "bomb" risk like nitrogen or oxygen, but they do carry some risk, especially when stored in a vehicle. Depending on the temp, Liquid Co2 can boil to different pressures at different rates. For example, at 72degrees F, Co2 can reach aprox. 860psi. When the temp reaches the 80 degrees F mark, the tank pressure can reach upwards of 1000psi. Therefore, depending on the temp outside (or in the truck), the pressure inside the tank can vary. Also, one must remember that the volume of Co2 (in either state) varies in the tank. For example, when the tank is running low, the volume of liquid is less, but the volume of gas is greater. Granted, the pressure remains the same while the volume of the gas/liquid changes. (This is why Co2 tanks will run steady pressure right to the point of being empty) Co2 also uses an incredible amount of energy (heat) when converting from a liquid to a gas. I'm sure some people have noticed their tanks forming frost around the regulator when under heavy use. This is why it is imperative to use the proper pressure regulators, as well as the proper air hoses that can with stand the cold temps. Your average yellow plastic air line that is used with normal air compressors pose serious risks when using them with Co2. The airlines can rupture due to the cold temps along with excessive pressure. (most air lines such as the one described are rated for 200psi) I personally have seen one explode when a pressure regulator failed. The guy walked away, but had a few pieces of plastic stuck in his face, as well as a ring in his ears for days! Just imagine 4 shot guns being fired off all at the same time...that was how loud it was. Companies like Powertank sell the proper braided poly-urethane air lines that can handle the temps, and are usually rated for pressures upwards of 1100psi. (they also make a kick-arse regulator)
Also, check out:
http://jrutherford.us/power_tank.htm
I have some pics of my Powertank setup registering over 1000psi on a hot day.
