clutch slave differences (1 Viewer)
Toronto, NSW, Australia
My 80 with h150f gbox and 1hz motor uses the Toyota pink slave cyl for the clutch, but I believe there are a few different versions. Do they all mount the same (two bolts)? What's the difference operationally? How far is the slave supposed to extend?
Always wondered.
Always wondered.
You best to match master and slave to the same year, unless you know for sure what you have is compatible.
There is differences. Not sure on details.
I found a difference in the length of travel when I swapped master and slave from different years.
Both bolted up, but I had issues with not enough travel at the slave cylinder
