Clutch Question?
My 79 Toyota LC clutch is going out i think.
When I push clutch all the way in and release it within the first little bit is when the vechile takes off.
Question is my clutch going out or is there adjustment or maybe slave clyinder, or master clyinder change out help this?
It is also loosing fluid over time.
cool thanks for the info.
If changing the master cyl. will I need to bleed the system or just switch out with new one?
You will need to bleed the system and I would replace both your master and slave at the same time as in my experience one always seems to die shortly after the other.
