Clutch Master or Slave Cylinder?
Check for leaks around the slave cylinder,check for leaks on the master cylinder and firewall where it mounts right above the clutch pedal/brake pedal,check the lines that may be cracked. Most change all three at the same time slave,lines and master you wont be dissapointed...go in there once and be done with.
