Clutch Master Cylinder
Gun Runner 5
ODD IRON OFF ROAD
Thomasville, GA
Does the BJ70 and BJ71 share the same clutch master cylinder and if so does anyone have the Toyota part number for this item?
Thanks.....1978HJ45
Not necessarily... need a chassis number and market to figure that out.
Also, is it boosted or non-boosted?
~John
My bad.....I will post that information later today.
........1978HJ45
~John
1988 BJ71 (JDM) ...BJ710001013 and the clutch is boosted.
John if you need additional information just let me know and I call your work number.
......1978HJ45
BJ710001013
06/1988 TOYOTA LAND CRUISER (BJ71V-MNX)
LX JPN HT 13BT MTM
p/n 31415-60010
I have the units for the HZJ series. They have the same bolt pattern, but are aluminum (and I find that Al cylinders usually last longer) and do not have the provision for bolting on the heat shield at the front of the bore. The tube also comes out the side and not the to, but that's an easy bend to fix.
I'll see if stock of the BJ71 & 74 version is available.
~John
BJ710001013
LX JPN HT 13BT MTM
p/n 31415-60010
~John
I assume even with the aluminum version the heat shield is required?
......1978HJ45
That does not appear to be a boosted clutch - no room for the booster with the turbo in the way
The booster is on the clutch pedal itself....kinda strange, I know.
.....1978HJ45
Booster is behind the firewall, master is available new from Toyota
I have provided the part numbers to my local Toyota dealer and all I got was a "deer in the headlight" look so I assume the clutch master cylinder will have to come out of Canada.
......1978HJ45
Nope, it's been de-listed (production canceled as of 2009).
~John
