Gents,
I have a lot to catch up on here and really appreciate the help I've gotten on threads and through PMs. I'll post a build thread soon as in the last two months I've put on new OME springs/shackles and a turbo on my 86' BJ70. Lots more the learn.
Now for a new problem.
First day after Turbo, I had to drive home from the shop ~20 mins with just the down pipe which probably heated up stuff that wasn't meant to be heated. On one brake application, the brakes were extremely "squishy" and and didn't brake till near full travel. I immediately pulled to the side to check the lines and I assumed the brake fluid was hot and that's why they were't performing. Drove slow on back roads, exhaust fitted next day, no more brake problems.
Today, going up a slight incline in 4th gear, vehicle loses power and RPM stay ~2800, I downshift to third, no power, RPM still ~3k. I pull off. Vehicle stopped and ON, clutch depresses all the way, I can shift into any gear, but transmission does not engage. Clutch returns normally.
During the turbo install process I also know I knocked the cap off the brake fluid res. and it did not seem to seat very tightly. Should this seal be air tight? Perhaps air got it during the install or when the exhaust was heating that area up?
It's a 50k km transmission, and before I look at rebuilding the clutch I want to make sure it's not either the master/slave cylinder or a bleed problem.
Am I on the right track? Bottom line, clutch goes to the floor and returns; I can shift to any gear while engine running or off, but no engagement of the transmission.
Edit: 5 speed manual H55F.
