Climate Control - Identify this harness
Doing some work to the a/c and while I was at it was trying to chase down an issue I was having with the climate control blowing warm air into the cabin even though it was set to cold so though maybe the air mixer was stuck open.
looks like the mixer is working fine up top, but i noticed this empty harness that appears to be connected to a wire that runs to the lower part of the mixer.
what i can't figure out is what it should be plugged into, if anything? i've poked around in there pretty well and dont see anything this would connect to. note that end of the harness is also fixed in a small bracket so its not like that end could really be out of place.
its the yellow-ish/offwhite 3 pin harness in the center.
any help you can lend is appreciated.
open
view
view
