After leaving my 98 LX470 outside in a heavy rain last week, I had a significant water leak from the hood latch into the driver's footwell. I know from other threads that this is likely caused by clogged sunroof drains.
The problem in my case is, my sunroof is inoperable (frozen cables). Since Ive never had any leaks from the sunroof itself, I've avoided doing the costly repair to make it operable. Therefore, I can't clear the clogged sunroof drain from the top down as is usually recommended.
Does anyone know if its possible to clear them from the bottom up? I suppose compressed air wont work since there's no clear exit at the top in my case, so I'd have to use wire/line to do it. Also, where precisely are the sunroof drain exit points under the car? Im having trouble locating them.
Any and all help appreciated - thanks!
