SOLD Clean North Carolina LX450
SOLD
This is a clean adult driven North Carolina 80 series with no rust. No accidents. Clean Carfax. Just hit 263k this week driving back from Virginia. I have owned this 80 series for several years and extensive preventive maintenance has been done. I've tried to document everything at NC LX450
$SOLD
Picture taken yesterday
Reason for selling is, I'm in the market for a 100 series due to growing family and life endeavors.
OME lift, adjustable RS9000 shocks, Has 5 matching 285's, dual batteries, hidden 12k winch, dual power inverters, set up for solar, GM mirror mod with exterior temp, HG and PHH done among pages and pages of maintenance and other goodies. Please take a few minutes to read through the thread on IH8MUD to see the care gone into it.
Not documented is I recently had the first and second rows leather recovered. Has perforated middles front and rear and seat heaters in the front. Land tank extensions on the drivers seat and new seat gears. Gear shifter is currently at the upholstery shop being recovered.
Clean NC Title in my name and in hand.
9/26/2014 213,230
Replaced Bank 1 O2 sensor w/Denso oem
9/27/2014 213,308
LEDs lights installed in hvac controls.
PCV hose replaced.
10/2/2014
CDL switch added.
10/9/2014 213,611
Drivers knuckle replaced. The original one has stripped caliper and upper trunion bolt holes stripped.
LED interior lights installed in headliner and doors.
10/28/2014
Kenwood DNX6190HD GPS BT
Rear Camera installed.
12/11/2014 215,776
EGR Valve Denso OEM
EGR Vacuum Solenoid Denso OEM
2/24/2015 218,xxx
Toyota OEM Dual Battery tray installed
Washer Bottle Relocated
3/15/2015 218,874
Oil Pressure sending unit replaced. Denso OEM
7/24/2015 221,576k
Replaced Belts.
9/13/2015. 224,911k
P0401 Code Defeated
Removed the throttle body and found carbon buildup in the upper manifold. All EGR vacuum lines were replaced. Carbon was cleared and throttle body was thoroughly cleaned. Pressurized air was blown through all hard lines with Carb cleaner
New Denso VSS was installed in OEM Location.
9/20/2015 225,139k
Distributor O-ring replaced.
12/25/2015 229,771
Stinger 80 amp Battery isolator installed
Aux Battery digital gauge installed.
2/15/2016 230,939
3x Radiator Hoses Replaced - Gates
Water pump Replaced -Aisin OEM
2/16/2015 230,939
Crankshaft seal Replaced
Oil Pump Seal Reaplced
Torx Screws Installed in Oil Pump cover
6/2016 235,286k Head Gasket and PHH
1. Toyota thermostat and gasket
2. Fuel Filter
3. Samco silicone PHH hose
4. Toyota timing chain set
5. Alternator Brushes
6. Toyota Head resurfaced at cylinder 5&6, pressured tested and valve seals replaced
7. OEM NGK spark plugs and wire set
8. Bosch Rotor cap and Button
9. BECK/ARNLEY head gasket set,
Includes all needed gaskets and sealing components required for a cylinder head job
10. Heat tape wrapped around main harness
11. Removed Oil pan, steamed cleaned and replaced with new gaskets
12. PCV Valve and grommet
8/19/2016
Expansion Valve, Dryer, A/C compressor, and all new o rings.
1/18/2017 245,273
30mm Spacer Installed
1/25/2017
Replaced Rear axle Lugnuts and Wheel studs
2/8/2017 246,446
5-285/75/16 Patagonia A/T installed
Alignment
2/23/2017
Replaced Rear Inner/Outer Wheel Bearings, Hub Race's, and seals.
4/5/2017 248,703
Full Knuckle Service.
-https://www.marlincrawler.com/axle/front-axle-parts/front-service-parts/service-front-fj80/fj80-knuckle-service-kit
-Sand Blasted Knuckles, Hubs, Spindles, Etc.
-New Timken Wheel Bearings and Race's
-New Toyota Dust Caps, Caliper Bolts
256,106
Slees 4" Castor plates Installed
OME steering stabilizer Installed
256, 210 10/14/2017
-Installed new front rotors.
-Repacked the front wheel bearings and reset the bearing preload.
-Inspected my winch cable and rewound it with correct tension.
11/3/2017 256,680
Installed the new reman Toyoda steering box
Installed Marlin HD steering upgrade. All tre replaced with 555 tre
1/12/2018
Replaced Both Front Calipers w/Toyota remans
EBC Green front pads
Slee extended SS Brake line kit of 7 installed
New OEM Asin Master Cylinder
Toyota OEM Rotors
2/3/2018 260,104k
Replaced both rear Calipers with remans, new OEM pads and Toyota rotors
@NC LX - those seats may be the nicest I've ever seen in an 80-series LX. Those images will haunt me as long as I own an LX450 have have to look at my, without a doubt, far inferior condition seats. Are they refinished or just really well kept? I don't remember ever seeing perforated leather in any of the ones I looked at, but then again, I've just gotten into this recently.
Thank you. I had the perforated leather done. I always try to add details that improve on what was already there.
It's still a little loose and not perfect in some places. I installed them in January and I hope as it gets warmer this summer they tighten up for @FJ Junkie
Whoever did the work did an outstanding job. They really do look new and the perforated leather adds a nice touch of class to the interior. No doubt that set you back a pretty penny.
NC LX,
I have been looking for perforated leather seat for mine; but cannot seem to locate any.
Pls lemme know how you went about obtaining yours....
