For Sale CLEAN 88 Suzuki Samurai (RARE) Hard Top AKA Tin Top MODDED (NYC/Tri State Area)
1988 Suzuki Samurai Tin Top. New York City.
CLEAN NY Title in hand.
PRICE
Alot of work has been done since original posting.
I have spent over $12k
Asking $8750 NOW (with everything Samurai relate that is in my shop, take it all).
I am only selling this because I barely drive the Sammy once every two weeks.
I have a Fj Cruiser that I wheel and my DD, and a Fzj80 that I have been spending alot off time driving and building.
(Just picked up and working on a second Fj80).
I picked this rig up back last Nov. And had it shipped up to NYC from down south.
This rigged sat in my friends garage over the winter until this past April. I finally got off by butt and address some issues it had when it arrived here in NYC. I also registered it in April and got it inspected in late April. I bought this to make it a DD and a weekend wheeler. I put less than 1.5k miles on it since I got it. Drove to and Wheeled it once at Rausch Creek PA.
This Sammy is one off the cleanest I was able to find.
Frame is mint, body has a few very minor dents and ding. Very minimal rust on the Body.
Rust at
rear pass fender. Aprox 1”x6”. Rest of the fender are excellent.
Three/four small rust holes (size of a dime or smaller) in the rear cargo floor pan area, by the gas cover.
These have been cleaned and rust reformed. And painted black.
Had plans to replace all the panels with OEM this summer. I am very anal and very picky.
Rig came with the following upgrades freshly installed by the previous owner.
Zuks Off Road - My-Side carb conversion - Harley-Davidson 40mm CV. $650
ZOR Zuks Off Road
Sky Manufacturing Stage 5 Spring Over. It includes DT3000 shocks, Driveshaft spacers, Crossover link, Longer Brake lines, and Shock loops. Here is the link. $675
Stage 5 Samurai Spring Over Conversion - Sky's Off-road Design
Calimini Completed Stainless Steel Exhaust - from the header to the tailpipe and it has the catalytic converter and muffler. $599
Exhaust Combo
It also has 4 Brand New Kumho MT KL71's 235/75/15s $620
Kumho Tire USA, Inc.
2” alum wheel spacers on all four corners. $100
New Alternator. $130
Items I have addressed.
When I received the rig it had a hard clutch issue. So I pulled the tranny and installed
New OEM clutch cable.
Brand New clutch and pressure plate (advance auto brand w/ lifetime warranty).
Brand New Throw out bearing.
Brand New Flywheel (SACHS if I can recall correctly)
New rear main seal on the engine (hey why not I am there already)
New tranny input seal.
New Zuk offroad Zor Thong for the tranny.
New OEM Suzuki Shifter Bolt.
New distributor o ring seal.
New synthetic blend gear oil for the tranny.
New Fram fuel filter.
New Accessory Belt.
New Fram locking gas cap.
New rear drive shaft U joint
DONE 5/22-Front seal
DONE 5/22-Timing belt & timing belt pulley, PCV valve. Motor Oil and filter
DONE 8/1- All new spring bushings (12x) Energy Suspension bushings in black.
I have since added or did the following
Brand New Zor Offroad top of the line t case cradle. $200
Suzuki SX4 Billet battery tie down clamp and oil cap. $100
Alum valve cover $35
Alum door handles from Lowrange both exterior and interior $65
Picked up a spare Tracker rim and blacked it out. $25
And ONE New Kumho MT KL71's 235/75/15s (a matching spare). $130
USED OEM black carpets , front, center and rear (NO cargo area or rear wheel wheels)
USED OEM radio Antenna (MINT condition)
NEW H4 halogen reflective headlamps with Sylvania Silverstars bulbs. $25+$30
Hella 500 fog lamps. $50 (REMOVED 9/28)
USED rear OEM Hatch with factory rear glass with defroster.
USED rear third brake lamp from a 98 4dr Tracker. $25
USED rear aftermarket bumper with two recover points and a 2” hitch
receiver. $150
NEW Tim Porter Hardcore 4x4 fuel tnk skid plate. $150
USED xtra OEM Suzuki dome lamp (pass side) $5
USED OEM Sidekick JLX map lamp. $30
NEW (2x) Red LED brake lamps to the bumper. $30
Brand New Cobra 75WXST CB, $100
New MNO 15” antenna cable $40
5’ thin NMO Antenna (this was to replace/fill the hole that was drilled by previous owner in the center off the roof). $35
New NMO cap (to cover the antenna mount if the antenna was removed). $5
All gear oil has just been replaced to Syn Blend. Front and rear diff, tranny, t case.
Modified (heavy duty) rear tire carrier , will accommodate even bigger set up.
Yakima Load Warrior with rack extension, With Yakima Towers, Yakima Cross Bars.
And everything is locked up with Yakima SKS locks even the rack to the cross bars.
2x Hella FF50 and Rear lamps 2x Harbor Freight lamps $700
Includes but NOT pictured.
-Rear small flange 3rd with lockrite installed. (had plan to installed this in the front with heavy duty axles and Evil Twin).
-Rear seat with bracket (will be bolting back in this week).
-Extra tranny from a 91 Sammy.
-1 Complete rear axle (from end to end) included small flange 3rd differential. from late 1988 Sammy with 80k street miles.
-1 Transfer case (small flange, rare from a late square vent 1988 Sammy with 80k street miles).
Rig has 110,000 miles
PHOTO ALBUM (new Pics added)
1988 Suzuki Samurai FOR SALE pictures by Siribx - Photobucket
PLEASE CONSIDER SHIPPING COST IF YOUR NOT PICKING THIS UP LOCALLY.
Shipping cost to you will vary AND IS UP TO YOU TO FIND OUT.
AND IT IS YOUR RESPONSIBILITY TO MAKE ARRANGEMENT for pick up and shipping arrangments.
I am willing to help meet the freight company within reason.
Rig is located at a commercial address with loading dock and hi low access.
The commercial address is in the Bronx, New York 10463 area,
Also consider the amount off spare parts (if this applies to you)
that will be coming with the rig. I will tried to package up all the spare parts and place them in the Samurai for transport.
Sorry but the upgrade engine is not going to fit in the Samurai for shipping.
Guys thank you all for the inquiries and pms.
Give me 2-3 days to make a complete list of what is on the rig currently.
I also need to inventory about 5 65gallon containers of parts. Some new stuff never got around to installing and some oem pulled stuffed from the rig.
Ok I am asking $8750
SERIOUS OFFERS
Here is the updated list of stuff on the rig.
Everything with a (small "new") is was bought new and un-used and installed. And the price which I paid (as closely as I can remember not including shipping or missing small parts to install)
Power Plant
1.6 16v swap with ALL NEW BELTS AND SEALS with Brand New 105 GM alternator with Bracket.
Motor was from my GF's Tracker it had less than 100k and I always maintain it.
Every seal possible was replace, if it was rubber it was replaced in engine, transmission and T case)
new Trail Tough modified harness running OBDII ($300)
new Trail Tough 16v adapter plate. ($150)
new Trail Gear 6.5/1 T case gears with Brand New Trail Tough Twisted TT (Twin Stick with only one stick) (Every seal replaced ($1100)
Tracker A/C compressor is install but need AC custom lines.
Tracker Power Steering with aux cooler with Petroworks aluminum (YES ALUMNIUM NOT STEEL VERSION) steering box mount. (mount $100, cooler $40)
new Sky Off Road Full High Steer Kit with heavy duty FJ80 Tie Rod ends ($369.00)
Drive Train (Front and rear axles have been completely overhauled. New seals new bearings. Everything new.)
FRONT Differential 26 splined Detroit installed ($350)
REAR Differential STOCK OEM rear 26 splined
(THE ARB DIFFERENTAIL WAS PULLED AND GEARED AND REBUILT 6/11 By EAST COAST GEARS. Has less than 10 miles on it)
new Spidertrax front Chromo axles ($500)
INCLUDES A BRAND NEW SECOND SPARE SET OF SPIDERTRAX CROMO AXLES with BRAND NEW BIRDFIELDS ($350)
Stock rear axles with all new bearings and seals (rig comes with a spare set of axles)
K.A.D. heavy duty rear drive shaft ($350)
new Brand New ARB compressor ($200)
Suspension
new Brand New Sky heavy duty full high steer kit heavy duty FJ80 ball joints. ($350)
new Front Trail Tough Missing Links and Sky (non M/L) rear on low mileage YJs springs. ($750)
new DayStar bushings with grease-able links front and rear ($150)
new Brand New Rancho 9way RS9000 shocks. ($300)
new Brand New 4dr tracker front calipers with brand new pads and Brand new Brembo rotors. ($250)
new Included but uninstalled rear disc conversion also. ($200)
Interior
Mint Recaro Seats from a EVO7. ($750)
new Cobra 75 WX ST CB (brand New) this is the smallest CB unit out. ($75)
Full OEM carpet in very good condition ($100)
Exterior/Armor
new Brand New Shrockwork bumper (no hoop) with Brand New Superwinch LP8500 with solenoid remotely mounted under the hood and control socket mounted inside the cabin. All heavy gauge Marine tinned/copper wiring. ($800)
new HardCore4x4 gas tank skids ($100)
Rear offroad bumper with recover points (forgot who it is made by) ($150)
Axles are trussed and Zor crab (both front and rear) rear only had one truss on the upper, front has both upper and lower. ($350)
new Upgrade H4 reflector headlamps with Sylvania Silverstars H4 Bulbs ($100)
new Brand New Hella Supertone horns ($75)
Yakima rack (extended) with custom Hi Lift mount and four lights. Front are brand New new Hella ff55 and rears are cheapo Harbor Freight brand. ($450)
new Brand New Harbor Freight flat tow bar (mounts to recover points on the Shrockwork bumper) So yes you can flat tow her home. ($75)
Rig will also come with two sets of rims and tires.
5 Pro Comp rims with 33 BFG All Terrain mounted and balanced.
new 5 BRAND NEW Pro Comp rims
new Mounted with Brand New Fire Stone Destination Mud Terrains mounted and balanced ($1500)
ALSO INCLUDED
REAR ARB diff RE-GEARED 5.37 just got rebuilt by EAST COAST GEARS new ARB seal and new bearing. ($1000)
One Spare 22 spline Diff (with 26 side gears uninstalled) ($75)
One Spare Tranny from a 88.5+ ($100)
ONE Spare T Case ($200)
One pair of spare rear axles ($75)
One pair of Brand New Spidertrax Chromo front axles. ($350)
One Complete stock Sammy front and rear seats (driver's seat has a slight tear) this was the stock set that came with the rig ($150) ($150)
Rear disc set up (not yet installed) with Suki front calipers, brand new pads and rotors.
($150)
[FONT=&quot]Boxes of spare parts some new some OEM stuff that was pulled.[/FONT]
Including are the following that I can recall off hand
OEM AC blower, brand new shock mounts, T case gears, extar steering box?, oem USA mirrors..... alot of stuff.
If it is Suzuki stuff it will go.
Any questions the best way to contact me at my google voice VIA text at 360 474 7457
Call me at the same number if you wish but most of the time I am in a loud environment so if I don't pick up is because of noise.
you can email me also at Siribxnyc at Gmail
I DON"T need to sell it. I don't have an issue with space to store either.
The only reason I am selling it because, I just don't use it.
The project is very closed to being perfect and finished.
I have a major NON Wheeling project that is a major priority that has been pushed ahead of everything else and I have a Fzj80 project I am bringing up on the priority list.
I can easily part the rig out and make more than the asking price.
I just don't have the time right now to part it out.
I figured someone else would be better utilizing the build.
Look at the parts list.
The project is close to perfection. Very very minor stuff left and that is if there is anything else.
BY THE WAY- The one thing that for sure was on my to do list was a interior roll cage with a 4point harness adapter to take advantage of the Recaro seats.
Here are my photo album
http://s76.photobucket.com/albums/j29/Siribx/1988%20Suzuki%20Samurai%20FOR%20SALE/
bump for a really nice build. glws.
