Long story sorry but kinda necessary... Gentlemen, I've had my 60 for a couple years now and I've driven it from Virginia to Kansas, from Kansas to Florida, from Florida to Texas and from Texas to North Carolina. It did all this on top of being my daily driver and has been running perfect. Next up, North Carolina to California. The trip will be made no matter what since I'm in the Marines. I need my truck fixed and I can't figure it out.
The problem, on my way from Texas to North Carolina the truck stumbled and quit after running for about 6 hours straight that day at 60-65mph. Due to the way it stumbled and quit, I thought my fuel pump went out. After sitting over night and two mechanics stumped, she started right up and ran fine for about 4 hrs the next day to finish my trip. She ran fine but kinda weak the next few days so I put a new fuel pump in. My problems were fixed and she ran more smooth and stronger than ever! Then, she didn't start after about 5 days of driving on the new fuel pump. This was due to the carb being empty.
So, I checked the fuel filter (new OEM btw) and it was fine. With the help of a friend, I observed that pumping the gas pedal did not pump any fuel into the carb. So, we put some fuel in the carb and bam, perfect for a couple more days. We also did some other basic checks and fixes, we looked in the tank by removing the fuel sending unit and everything looked good, I replaced all vacuum lines with silicone hose and we double checked for leaks by spraying carb cleaner everywhere we could get to and as best we could around the intake manifold. No reaction.
The truck was still running weak so I took it to a mechanic to get some measurements with some tools I don't have. Lucky/Unlucky me, the truck quit as I rolled into the mechanic's parking lot after a 45min drive at 55mph. No kidding.
Here's where it gets interesting, all electrical looks perfect, no vacuum can be detected, but overnight without fail the carb will go dry with absolutely no sign of a leak that can be detected by me or a mechanic. Also, while the engine is running at idle, a fuel pressure gauge will show zero psi. BUT if we clamp the fuel return line the fuel pressure jumps up to 5psi and the fuel filter fills up and stays full and the carb doesn't empty out overnight. I now have a clamp zip tied closed on the fuel return line and have driven on that for 4 days without a problem. It starts right up in the morning and runs almost perfect around town and on the highway. Still has an occasional stumble. Thoughts, Opinions, Advice? I have or will provide pictures or video of anything you'd like to see to help me diagnose this problem. Carb was rebuilt by TLC4x4 about 10 years ago.
Thanks in advance.
Thanks in advance.
