A potentially "easy" way of confirming whether rear springs are too stiff would be stuffing some 400-500lbs of weight into the cargo area and going for a drive. Got any sand bags?
I'd say do whatever you can to use that adjuster and see if damping alone can resolve your issues. You may be maxed out, and have all you need to address the ride, though yes swapping springs to reduce some height could be of help too.The front end rides pretty well for sure. The rear ended is a tractor over asphalt bumps. I tried adjusting the rear shocks to no avail. It just rotates the entire shock housing. This could also be the culprit. I wonder if spraying the adjusters with lithium grease would free them. I would probably be better off going to a 2720. Still may just put in a whole new system
No, butA potentially "easy" way of confirming whether rear springs are too stiff would be stuffing some 400-500lbs of weight into the cargo area and going for a drive. Got any sand bags?
thank you! I let you know if my adjustment doesn’t create the results I’m after. If I run the tough dog springs, I imagine I’ll need to lower the front shocks as well to keep everything level, correct?Sounds like you need lighter rear springs. It’s pretty hard to find aftermarket springs designed to lift a truck that aren’t heavier, but you don’t sound like you need much extra load
If you want to try my Tough Dog standard springs, I just pulled them from my truck to upgrade to heavier springs as I’ve added weight. Happy to send them to you for the cost of shipping. they are a lower spring rate than the OME you have (240 vs 275), though still higher than stock. I found they were perfect with 300lbs or so in the trunk, and were firmer than stock but perfectly driveable when I was unloaded.
Probably not. I had a decent rake (rear higher than front) before I put on my rear bumper. You should be able to swap in any rear springs and your height shouldn’t actually change much, as heavier springs actually tend to be shorter but have thicker coils which compress less.No, but
I thought about Kings. I wonder how they do in humid climates and the occasional salty roads. My previous ICONS started to develop rust on some of the parts such as the shock threads. I’ve heard great things about the new Dobinson stuff on other older LC’s and other Toyotas but little info on 200’s. They are pretty with the purple dialed and gloss black housings but not as pretty as Kings and I would think Kings are a bit more.If you do swap them let us know what what the performance is like between the two.
If I was spending $3-4k on a suspension and had ruled out BP51's I'd look hard at Kings next. That said I don't have any experience with the Dobinson's suspension so it may be great as well.
Well, it’s just the adjuster knob to make it easier to see and locate. I think it looks pretty nice. Spring color is optional as I would just stick with black.Personally I want my suspension components to just be black and I wish more companies would stop painting theirs the brightest colors they can find. I don't need to show them off.
Kings will depend on the options, they could be more or less depending on the level of customization you feel you want
Paging @CharlieS (I think)I thought about Kings. I wonder how they do in humid climates and the occasional salty roads.
Thanks for the ping.Paging @CharlieS (I think)
I would also prefer plain black.Personally I want my suspension components to just be black and I wish more companies would stop painting theirs the brightest colors they can find. I don't need to show them off.
Update: I set the compression to 2 on the rears and was able to set Rebound to 6 on drivers rear side but can’t budge the passenger rear side rebound dial. It definitely made the rear end much softer and almost a little floaty after going over road bumps. The frustration I’ve had with trying to adjust them is making me seriously consider just swapping them out for Dobinson
