Hello! I just got off the phone with Chilkat and talked through all of these issues. Apparently, FJ80s came from the factory with 9.5" rear differentials and 8" front differentials. Apparently the high-pinion 8" front differential, e-locker variety was actually stronger than other front axle offerings because the gears are reverse-cut and engage on the same side (right) that engages when locked. Toyota combined that axle with the 9.5" rear in their heaviest truck/LC offering at the time (the FJ80) because they were the strongest. So, to achieve mechanical differential lock actuation in an FJ80, you actually need one 9.5" kit and one 8" kit from Chilkat.
All news to me, and very appreciated insights!
I already knew that the FJ80 axles had the biggest/strongest birfield joints of any Toyota solid-axle. That, along with the facts that the rear FJ80 axle is full-float and disc-braked were my main reasons for selecting the option of doing a full axle swap (and custom-mounting FJ80 axles underneath
leaf springs) to achieve diff-locking functionality, instead of the option of installing ARB air-lockers in the FJ62 axles. Cost was essentially same given my situation and access to parts, and the fact that the ARB air-locker that works with semi-float axles is a little weaker than the one they install in full-float axles sealed my decision that factory Toyota locking axles from an FJ80 belonged under my FJ62.
I can't wait to have full mechanical actuation with Chilkat products in both Front and Rear of my superig!! Pictures will come when everything is wrapped up!
