Its a worthy thread!!! The old ones are the good ones!
My rig (1994 350)with a mechanical fan with no shroud and the original radiator goes to 195 hard driving , and it has been to 220 (fan clutch fan not working) at that temp it was overheating and I had to pull over to let it cool down.
Back from the dead again...
All this talk of temps but no mention of where the temps are being measured. In the head, intake manifold or somewhere else? I assume in older SBCs we are talking about the stock location in the right front head.
I know that each rig will manifest different temps and this has to be taken in to account but the wild variations in what is deemed "normal" or acceptable is interesting.
That being said, what should the temp range be for a carbureted sbc 350 with the temp sensor in the intake manifold?
) aftermarket temp gauges, aluminum radiator, stock fan blade on a partshouse HD clutch, stock shroud.That being said, what should the temp range be for a carbureted sbc 350 with the temp sensor in the intake manifold?
Interesting, you should not be overheating until your up to or over 240, most cases 260.
I have dual electric fans and the first fan kicks on at 195/200 and the second fan kicks on at 220. Red line is at 260.
GM/Chevy V8's traditionally run at between 195 and 220 which I beleive is considered normal!
Assuming a Gen 1 SBC, normal operating temp range? 185°-210° assuming a 195° thermostat and temp sensor in the intake manifold. On hard runs where you are pushing the motor you might see 220-230. If your temp sensor is in the head, you can expect readings 20° hotter (or more) on a hard run. While sitting at idle, the sensor in the head (between 1 and 3) will read slightly warmer than the intake manifold position, but will easily spike 20-25° when you put your foot in it.
I've seen 250 in mine (temp sensor in the head) climbing some fairly serious grades, at highway speed, ambient temps of 110. Temps come down fairly quickly though on the down grade.
Did you read this thread from the beginning? Lots of good info. I’ve been dealing with my SBC 305(w/carb). I put a new Champion radiator and Spal fan in and the fan relay kit from Champion Radiators dot com was recommended at 170-180 for on and off. Well that was a waste of money and I should have done all my homework. Cooler isn’t better as many hot rod/Chevy forums would have you believe.Once again this ol thread...
I got an old carburated 89' 350, all stock, fan, radiator, even thermostat (180f), radiator cap is 9lbs.
These days my radiator cracked, after i got it fixed and put it back the temp gauge (original) showed me a little bit warmer and it fluctuates real bad, i would say between 180 and 210, it goes up and down all the time the first 10 minutes i start driving, after that it goes to 195 or 200 maybe, the middle mark on gauge, it seems like it want to pass the middle mark, before the rad got fixed it always ran on 180, even in hot days and after the rad fix is running warmer, i dont really know exact temperature im running since my gauge show min temp as 40 and max as 130 so i would say the middle mark is on 90.
Almost forgot, when i drive an hour or 2 on a hot day the temp goes up a little bit, i assume if i keep driving the temp will keep going up
My questions are, should i be worried about a inner crack in my engine? Maybe is my thermostat gettin sticky? Should i get the 160 or get the 180 as it is rn? What if i put a lower pressure rad cap? This may help going some degrees down on hot days?
My mildly built 350 ran great, except trying to pull a hill. I had a electric fan that fit nicely in the stock fan. I could idle, crawl and cruise the highway no problem, until I needed to drive over the pass. Stock radiator that was rebuilt. Switched to a Taurus fan and life is good. I also followed the internets advice and found a Volvo relay that lowered the starting amps on the fan.I am running a 96 350 built to 350 hp with earlier ram horn exhausts. I pretty sure the radiator is an original 64 tlc with a shroud. The fan is a mechanical 5 blade and no clutch. When newer, the motor ran cooler but the last couple of summers on the hottest days temps have creeped up to 200-215. At 215 I start getting vapor lock and have been working to insulate fuel supply but so far no luck in fully stopping it. Have to be really careful in slow traffic ... like getting caught on stopped traffic on the interstate. Thinking about changing radiator and fan but like the original look!
