bloc
Last oil change I noticed something strange from the TRD oil filter I went to install. When installed on the filter housing cover, the perforated tube was offset to one side. I remember thinking “huh” and proceeding with install.
I did an oil change a few days ago and another TRD filter, same thing. Pull the filter back off and have a close look.. the damn thing is crooked. Slightly parallelogrammed.
I dug through the five I had on the shelf, and all but one were crooked.
It is slight, but with so little spring pressure from the filter support tube pushing the filter into the top of the housing, I’m not sure the upper soft seal doesn’t have a gap and oil isn’t bypassing the filter.
I didn’t get a pic but standard OEM filters are a different construction and with a molded plastic upper seal are perfectly square. I had one of those on the shelf too so installed it.
I’m attaching some pictures of what I found. Given the poor quality control of the batch I have, I’m opting to use standard OEM filters for now until I find a model I like and can actually trust to filter the oil.
If you all have these on the shelf and the tool to check square, maybe give yours a look. I wonder how widespread this is.
This is visible without the right angle if you look closely.
Good filter on left, crooked on right. Slightly different markings on the filter, not sure if it’s a different production run or something.
