fyton2v
I'm getting ready for the "big one". Is there anything missing from the list, or that should be omitted from the list? Much of this comes from Toyota's service recommendations and things taken from the forum. I’m hoping to get the parts from C-Dan and have one of the nearby dealers to the labor. I do not want to try this at home.
Replace serpentine belt
Replace fuel filter
Replace water pump
Replace thermostat
Replace front crank seal
Replace idler bearing
Replace timing belt tensioner bearing
Replace timing belt
Replace engine oil and oil filter
Replace engine air filter
Replace engine coolant
Lubricate propeller shaft (4WD)
Lubricate wheel bearings and drive shaft bearings
Re-torque propeller shaft bolt
Replace transmission fluid
Replace front differential oil
Replace rear differential oil
Replace transfer case oil
Replace limited-slip differential oil, if equipped
Inspect the following:
Ball joints and dust covers
Brake lines and hoses
Brake linings/drums and brake pads/discs
Drive belts
Drive shaft boots (4WD)
Exhaust pipes and mountings
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
Fuel tank cap gasket
Steering gear box
Steering linkage and boots
Thanks
Replace fuel filter
Replace water pump
Replace thermostat
Replace timing belt
Drive belts
Steering gear box
Thanks
