I see no reason for having axle on jacks and half the vehicle on jack stands when it doesn't need to be.
Being a newb at this, I can only give so much input, but I have changed my leaf springs. I'm a safety professional so I took the following precautions:
- used multiple jack stands - 4 in all - 2 under the frame, 2 to support the axle
- placed removed tires under the car in the event somehow the car fell off the stands (I live in earthquake country)
- have a ratcheting strap to be able to pull the leaf springs into place - mine were a really tight fit and I could not push them in by myself. Plus trying to hold them in place and push is pretty difficult. They're not light so if one were to fall on you it wouldn't feel very good
- use lots of grease - friction in this case is not your friend...
As for installation, make sure the leaf springs are pointed in the correct direction. On the OMEs it isn't clearly apparent - ask me how I know.
Don't forget the torque wrench. Some nuts don't need to be tightened much.
Anyhow hope that helps. Good luck with it and be safe!
Yup that is correct - you just don't get instructions indicating that. And sometimes when you call OME tech support you will get the "arrow points forward" answer like we assumed. Doh!Most new OME leaf springs come with yellow arrows painted on the top. The arrows point towards the fixed (non-shackle) end.
One spring at a time. Jack stand under the frame just in front of the front spring hanger. Leave tires on. Block tires from moving. Other spring will keep axle from rotating. Use a ratchet strap on the springs by the shackles. Use a Port-A-Power to press the shackle out of the bushings. Ratchet strap will keep the spring from spreading apart. Use the Port-A-Power to press the front bushing. Use a bolt or some type of pin to press it out once flush.
Mine were really easy (no rust). I think the best advice you got above was to leave everything loose on BOTH SIDES and you won't need to pull and tug with straps or porta powers etc (unless the new springs were made incorrectly.) Don't try to install the forward end of the springs with the rubber bushings both installed. It won't fit. Install the bushing that is on the inside edge, but wait until you have the end of the spring in the forward shackle, then push the remaining bushing in through the big hole that the mounting bolt goes through. Put some grease on all the bushings (some people say silicone grease and others say lithium). Tighten each pair of springs gradually, alternating the tightening so both sides are tightened at roughly the same time. That avoids the twisting and binding that many complain of.
