Changed belts and now no charge from alternator
Raleigh
I recently changed the drive belts and ever since, voltage sits at mid 11 volts at the battery and alternator when the vehicle is running. It was always mid 13s to 14 volts prior to the belt change. OEM belts and nothing else done during the service. Any ideas? It doesn’t make sense and not sure where to look.
I didn’t use a gauge. It’s extremely tight though. I’ll get one to make sure that’s not the problem. Thanks!
Belts were the correct tension using the gauge and still low voltage and battery is not charging. I went ahead and pulled the alternator, check the brushes nd all wiring. Brushes were within spec, but changed them anyway since I had new ones sitting around. After putting it back together and running it for a minute or so, I noticed the alternator is scorching hot. I was thinking regulator, but I thought the symptom of a bad was high voltage, not low. Battery is less than two years old. Is this a sign of a bad alternator?
Was the battery drained very low before hooking up the alternator?
What Voltage is/was the alternator putting out when it got hot?
Good connections all around?
Wait for others with more electron knowledge to chime in.
Heat is the result of too much current being shunted to ground. The regulator controls the output of the alternator; the generator just spins.
I'd be the failure is coincedental. There are function checks in the service manual for the alternator.
The rgualtor cannot be "rebuilt"; at leat not easily and not unless you're a) a glutton for punishment, or b) just really into science projects. Unfortunately, a new regulator is almost the same cost as a new alternator, so if it was me, I'd just replace the whole thing.
"---unless you're a glutton for punishment"
I'm a glutton (but not an expert) and yes it was a pain in the arse rebuilding an alternator. I did it more as a learning experience but it was a lot of work; taking the case apart, pulling the bearings off the rotor shaft, cleaning off 25 years of oil and grime, sanding the slip ring, re-coating the rotor and windings with the correct insulating varnish (found micro-cracks had develop on the wiring from age/oil exposure), new brush pack, bearings, ---- .
You can get really deep into it (replacing the slip ring if worn for example) but can save money by shopping around for aftermarket parts as the OEM parts cost more than a Toyota Remanufactured unit. Downside is that most of the (affordable) aftermarket parts will be made in Chy nuh or (maybe better, Korea). IME the Rectifier is something that seems to pop (bad diodes) before the voltage regulator goes bad but while it's all apart might as well replace it also.
If all someone wanted to do is replace noisy bearings and a brush pack for example that wouldn't be too bad but once it's apart you'll end up wanting to replace/repair everything else so better (less painful) to just buy a new OEM Reman unit while they're still available.
If I ever find my rebuild photos I'll post them up.
For future searches FWIW:
Thanks for the responses.
Dealership was running a July 4th deal with free shipping so I bought a new alternator. Worse case if that doesn’t fix it is I have a cheap spare.
