SOLD Central Florida: 1985 fj60
Year
1985
  1. 60 Series
Florida United States
Color
Beige
'85 TX > CA > FL truck with 259k on the original 2F, h55f that the previous owner put in it in the mid-2000s
Older style ARB winch bumper
Rear seat belts with shoulder belts
SOR diamond mat rubber in rear, SOR carpet kit
Within the past couple years I've added: new A/C
new OEM power steering pump new radiator new OEM clutch
new OEM clutch master & slave cylinders with new hose, new OEM brake master cylinder new front calipers
Old Man Emu 2.5" Heavy suspension
FN wheels 16x8
BFG KO2s 295/75R16
Dynamat under all of the carpet
Trucklite LED headlights
Optima yellow top battery (2yrs old)
Reupholstered with marine grade vinyl in original seam pattern. Color matched to dark brown of interior factory components.
Total exterior restoration done in December '17 and resprayed in the original 4E9 beige
New door handles
De-chromed windows with WagonGear window welts and OEM gaskets
WagonGear door seals
Things that it needs:
Has a bit of rust on the rear driver side roof gutter. Not massive and not leaking but would need to be addressed.
Leaky radiator hose that may need replaced.
Tires are at about 30%
TREs, spring bushings, and motor mounts are tired.
Carb could use adjusting/cleaning. (It idles around 1100rpm which seems to be related to a sticky fuel plunger, not sure)
Tag light has a grounding issue that I’ve never bothered to investigate.
It’s desmogged, so that may or may not be an issue for people in certain states.
$20,000 firm
Rhino rack is being sold separately, but I could include it for an additional $600
DM me for more photos or with any questions.
Good looking FJ60.
I really like those FN wheels, can't say I've seen them before. They look like a modern version of the stock wheels and suit the truck perfectly. One of the better aftermarket wheel solutions. Any more pics to share?
Good looking FJ60.
That’s exactly why I got them. They’re the 16x8 Countersteer Type X model. Dustin at FN had them bored out to fit the hubs at no extra charge. I’m a big fan of FN for every Toyota I’ve had.
  • Like
Reactions: 405
How would one of these do as a daily driver on my 35 mile round trip commute to work? 65 mph top speed and some stop and go traffic. Been waiting for one like this to pop up and I’m located in Sarasota florida. Right now I’m driving a 2017 Manual transmission 4 cylinder access cab tacoma.
This has been my daily for a few years. One thing is for sure, you won’t get the same mpg that your Tacoma gets.
