- Thread starter
- #21
It took me 5 weeks to get the trailer painted and the shock absorbers installed. Life just kept getting in the way of play....work! But the trailer is back on the wheels.
After it was on the wheels, I had to weld the top of the shock mount and when I went into the trailer. I was surprised to see how much the suspension dipped. So, I had a buddy of mine come and sit it in with me. Our combined weight was 375 lbs and the trailer dropped about 1.5". I though that was too much so decided to add leaves 2 and 4 that were initially removed. The frame to axle distance went from 8-1/4" to 9-1/8". But our combined weight now dropped the trailer only 5/8". I felt that was better as this is still going to be a utility trailer of sorts and I never know when I will need to carry a heavy weight. More polyethylene inserts we added to the additional leaves and are continuing to allow smooth movement of the springs. I feel that the suspension is working as it should.
Some minor welding to be done and then it is time for fiber-glassing.
I got hold of an HP book called Fiberglass and other composite materials and with the information inside and well as reading up on the internet, especially the West Systems Epoxy fiberglass whose products I will be using. If it can work on a boat submerged in the water for years on end, it can work on my trailer that will at the most get rained on. Although the wife did say that since it will be waterproof, it can be turned into a swimming pool if needed. Hmmm...
... an expedition swimming pool!
But the day is still ahead of me, so back to work. Will be starting on the fenders today as they are small and if I screw up, not much material is wasted.
