Carter fuel pump 24V
Does it look like this? My 12V version was a delco. Lasted 65000km. I "think" my 24V is a federal mogul but it might be a carter...
Talking to the 6.2/6.5 guys that is typical life for one of these.
Brad, is that the part number you gave me?
P61295S 03A09B
And where did you pick that up from?
Tom
Back at the tank, as close as possible to the tank on the inside frame rail.
It will be high and out of harms way.
Nope, simular but different.
I will get it tomorrow and shoot a picture of it.
Hi,
What's your Cruiser's model... I never saw one of this on european's Hj6x
OursSauvage said:
Hi,
HJ60 with a 1HZ and very deep and large long range fuel tank.
OK,
I understand, you put this pump because you change the tank, it's not the original assembly.
Thank's
(Désolé Max... mauvaise piste ;) )
i have found in a couple test i ran on my own trucks that a pusher pump inline with the factroy pump increases performance...
cheers
cheers
I have been told that more than once by the Ozzie boys, good to hear it from a local.
Looks identical to that pump you posted, picked it up today.
Are you saying it is a lesser pump?
Also did you buy thos fittings or make them up?
The box has Carter on the top and in small print is Federal Mogul.
Thanks
Rob
Not sure what you mean about lesser pump.
the fittings are a custom item
65000miles seems like a short life for the pump, the pump you posted I thought was a low end pump? If so mine looks identical.
Rob
I am told from my diesel shop that that is typical life expectancey, from the delco or the carter...
