Carburetor Linkage - binding (1 Viewer)
brooklyn
Hi all, can’t seem to keep my carb linkage from binding. Tried making a few adjustments to the positioning of bracket but still no luck. This is a City Racer carb, attached to an 85F2, sitting in a 67’ FJ40.
Any thoughts? Is there an alternative bracket setup for these?
Who advised you to attach your cable in this very very unsafe manner and hook it all up like this ?
This is a recipe to a crash 💥 into a object in front of you unintentionally
No joke here about safety …fyi
You need a all hard parts linkage kit consisting of push rods , balls and sockets …
Since you have a 2F engine and a 2F engine carburetor correctly
Installing the proper 2F accelerator linkage set up from peddle to the new carb is a logical approach and the best and only path forward
Matt
Agreed, hard linkage is best. I am dealing with the same issue on my 71 body / 69engine with a city racer carb.
The bend in your cable will result in “squishy” or poor responsiveness in throttle response. Additionally, from testing on my vehicle, the secondary fuel jets won’t activate with the stock pedal linkage. You will need to increase cable travel.
I am currently trying to fit a 73 bracket to the carb and cable. This requires a new cable with barrel stop and linkage. @ToyotaMatt gas cable. Maybe someone else on here or in wtb section has the 73 carb bracket. Photo shows 73 bracket & cable. I am missing the linkage arm.
Alternatively I think @ToyotaMatt has a 3FE bracket mod for the carb that could work. I haven’t researched this much yet.
- That linkage bracket and bell crank require the END OF LINE Barrel Stop Cable as shown above
I also have a complete rods and ball and sockets linkage kit for you to consideration
It’s all restored and freshly gold zinc plated too
Hi Matt — can you provide link to kit? Looks like I need everything from carb to gas pedal.
Didn’t see on your site so
I must be using wrong search term.
Interesting, very interesting. The ball and sockets on my73 bracket were heavily pitted. Will need to get that.
I was going to Frankenstein a Lokar linkage. @ToyotaMatt I will have to take you up on the linkage.
When my balls and sockets got sloppy and dangerous as @ToyotaMatt stated, I made the swap to his very nice and golden linkage parts for my 1981. It made a big difference at the pedal to have have a tight linkage setup.
devo
Wait a minute, that is the 73 cable I got from you a while back. Fits pretty good although initial fit up seems like the cable length is a little long (ok just loop it and zip tie secured).
@devo what does the right side of that post connect to? I think this is the challenge with early style throttle connections.
58-67 had mechanical linkage
68-72 and earlier had straight end cables
Late 72-73 had a barrel end cable and bracket to mechanical linkage
74+ had mechanical linkages to the pedal.
T-TEN Linkage Class is in session ....
TECH Video Below is golden 411 ,
i suggest making time to get enlightened and up to speed , any other way is simply Passe'
@RiggityJ,
I could tell you that is the Torque Rod and it goes to the firewall. But it looks like T-Matt took the words and videos right out of my mouth.
If anyone can steer you right on this subject its ‘ole @ToyotaMatt
devo
For the person who started the original thread, you would probably be better off scrapping the whole linkage/ball socket/city racer carb setup and just getting an earlier cable actuated Aisan carb that will be more compatible with your '67 accelerator pedal and cable. Easier and better IMHO. Carb from late 69 to 72 would work and have proper brackets, etc. Not sure about your Air Cleaner, but if you went with the early style it would fit your 67 and the carb better than the 2f style.
maybe i forgot a small detail : 🤔
Still trying to figure this one out as I have a 85" F2 engine in my "67 FJ40. So for the background, I had a trollhole carb with the current "not so perfect" linkage for many years, that carb got fouled from a dirty gas tank. To keep the truck on the road, I purchased the CityRacer carb, which runs great. I also have a rebuilt Aisan carburetor, which could replace the CityRacer or just be a spare for future use.
Ideally, I would like to stay with a cable setup and was looking at the 72/73 linkage as a possibility, but that linkage seems very hard to find. So for @ToyotaMatt, would the bell crank assembly help me out and is so, do I need additional brackets?
If I go to a newer setup that is found on the 85 carbs, how involved is this install in a '67? Have a car show planned the second week of September and trying to see what I can do before that event -- first time entering a show and have been preparing the truck for months.
Amy advice is greatly appreciated.
The bellcrank Matt is showing is off a 1HZ, so you can see how it truly mounts. The clearance for it is no good on a 40 unfortunately. Here’s a pic of the 1hz linkage. You can see how it connects to the injection pump.
@mattressking - thanks for the photo. Still working on a solution — ruling out some that won’t work helps!
