a couple of months ago i was having stalling problems and i thought i had fixed it.....steps taken (its a carbed unit SBC)
1. cleaned fuel tank
2. installed Vented gas cap (de smogged system)
3. Two new fuel filter (glass type)
4. new electric pump 4-7 psi
5. new fuel lines tank to carb
heres the scenario.... after installing new lines,fuel filter and e.pump obviosly the lines are still empty of fuel until i turn on the ignition....so i turn it on and then i can hear the electric pump (loud) for about 5 seconds and then it quiets down....now the fuel is at the carb.... 1 click and it starts.....
next day went for a drive stalls again gasping for fuel and bucks....turned ignition off and then turned it on.....i can hear the electric pump (loud) waiting for the 5 seconds for it to quite down ........and it does'nt, this is where the glass fuel filter comes into place looked at the one before the electric pump...full of gas and no debris....so i move on to the next glass filter before the carbuerator.....full of gas and no debris either......But the electric pump is still loud as if its still trying to prime fuel to the carb (i dont get it ...the fuel is there why does it try to prime.......so i try and start it anyways..... hard starting and then started running but the carburator back fired...and died.......so i turn the ignition on again and the electric pump is actually quite this time but working.....i start it and starts right up. I looked under the rig and no fuel leaks. whats wrong with my carb would a stuck float do this,.I hope someone can shed some light on this problem
By the way i can recall the PO told me he had the carbed fixed in the past so it wouldnt stall on an incline or off camber situation..
i wonder? any thoughts any body? Thanks in advance to all and happy holidays!
