After sitting overnight, the fuel level on my carb drops to the bottom of the sight glass. I've taken it apart twice in the last two days, but can't pinpoint the problem. The engine runs fine, starts up easily, idles great, so drivability isn't an issue, but it just bothers me to have fuel dripping down my engine all the time.
It's a 1975 stock 2F engine with stock carb. It's not desmogged, but I did take the EGR cooler and EGR valve off because they were plugged up by the PO anyway. So right now the carb is capped off at the EGR insulator, I don't know if that makes any difference. And I did find out that I'm missing the o-ring on my idle solenoid, but can't see how that would affect anything.
I disconnected the fuel pump lines thinking maybe it was siphoning back torwards the fuel pump, that wasn't it. No visible leaks on the outside either. First time it was happening, it was leaking from EGR valve, that's why I took it off and capped off the tube coming from the EGR insulator. It's not doing that since I took it apart again yesterday (I uncapped to check), but the fuel level is still going down. One thing I do know, it's definitely draining into the intake manifold, I saw gas at the bottom of the manifold last time I took the carb out. Nothing dripping from the venturis when parked, I can't see any fuel dripping down the walls anywhere, and I inspected the casting carefully and no cracks, so I have no idea where the leak is coming from. The only possibility I can think of is the power valve? Thats' the only thing below the fuel level aside from the jets. Is there supposed to be a check ball or anything in there? When I took it apart, there's just the spring plunger and end cap orifice, I don't know whether there's anything else missing inside. This problem is starting to drive me crazy!
