- Joined
- Jun 28, 2002
- Threads
- 165
- Messages
- 2,105
- Location
- Colorado Springs, CO
- Website
- www.mntoyx4.com
I have been tinkering with my carb n stuff past couple of days. Just tuning kinds of things. Couple of things turned up that I have questions about. 1985 FJ60
It's not running badly, but I just want to get it running better.
Idle:
I set my idle @ 650 rpm (or real close to it). While I am driving, if I come to a stop it will idle at close to 1k, until I rev the engine a bit which makes it fall back down to 650. What may be causing this
While turning the idle screw the motor won't change idle until I rev the motor. Does the linkage need to be lubed? I'm assuming I could just use some lithium grease at the joints.
What is the adjusting screw that is in the front of the carb below the sight glass?
Timing:
I set my idle at 690 rpm, and disconnected/plugged the vac lines to the advance deeleo bob on the side of the dist. I also disconnected/plugged the 2 vac lines the are on top of the distributor. I cannot turn the distributor any further counterclockwise which I believe advances the timing. The bracket that holds it down lets is move only so far. I'm pretty sure that I need to advance it, because if I turn it the other way, it starts running crappy. Am I missing something here?
Idle:
Timing:
