For several weeks now I've been suffering with an annoying tick-tick-tick-tick sound as I go down the road. It sounds EXACTLY like stones stuck in the tread of the tires (BFG KO2's). This makes sense, as I have been driving on several gravel/dirt roads for about a year. The noise wasn't there when I had the winter tires on (Nokian R3s), or at least I don't remember it, but I could be that I wasn't driving with the windows down and didn't notice it. 2015 LC, ~93K miles. BP-51 suspension, ~2" of lift. Frequency of noise is tied to speed, happens on smooth pavement. Truck is otherwise very smooth.
Had the day free today so I decided it was time to find the source. Did the following:
* Put it up on the lift, carefully inspected all the tires with my best reading glasses and a bright light. Found a few very small stones (<2mm) in the tread, and one tiny nail that is not leaking. Pried everything out with a screwdriver.
* Spun all the wheels, nothing. Perhaps this is because they are not at ride height. Wheel bearings feel tight, no looseness at all.
* Carefully inspected the front CV axles. Nice and tight, none of the boots are torn or leaking, bone dry.
* Checked driveshafts, both feel very tight, and they get greased every oil change.
* Removed the rings from all the RW wheels. Not as hard to do as I expected, my Makita impact and a new Bosch T30 bit popped all the cap screws right out. Ordered an M8x1.00 tap and die to chase all the threads, will re-assemble later this week with fresh blue Loctite.
* Checked torque on all the lug nuts.
Just took the truck for a quick drive, the noise is still there. What's odd is that I can clearly hear it from both sides if there's a wall or building to "bounce" the noise off of, and I have the windows down. If I turn very slightly to the right, the noise goes away on the left side. Same if I veer to the left, noise disappears from the right.
My winter tires are a pain to get out, so I'd rather not resort to swapping them on.
Any ideas on diagnosis greatly appreciated.
