SOLD Canada: 1PZ injection pump f/s
JDM Journeys
Moderator
Calgary, AB
Got this on a partial parts exchange from a buddy who had swapped it out of his 1pz for one with an HAC on top of it. It was working at the time but I don't have any info about the kms etc. My original plan was to use it as a core to try to get a 1hz pump out of AUS (without having to pull mine first and then wait on it) but I ended up having mine reconditioned locally, so this piece of 5 cylinder holiness can do some good for someone else.
Key is still in the drive shaft. Fuel "out" manifold is still bolted to top. All adjustment screws appear to be in place. Max throttle screw still has the security wire on it. Fuel cut solenoid and harness are also intact. Output pipes are capped.
I was told it worked when it was pulled but I'd still have it reco'ed first, just based on the effort to pull it out.
I'd like to get $425USD OBO, plus you're responsible for shipping from Calgary, Alberta to your location.
Labelled as
22100-18051
09600-8850 0
8051
For anyone that has a 1PZ, they would be smart to keep one of these on hand. This is a great price. When I owned a PZJ70, I had to get a rebuilt 1PZ injection pump from Dave Stedman direct from Denso. None could be found elsewhere at the time and it was NOT cheap. Due to the short production life of the 1PZ, these pumps are rare. Get one while you can in case your old one is not rebuildable which happened to me.
