Can I borrow a SST?
North Cadillac
I'm fixin' to rebuild my rear axle and need the sst for the rear bearings. I'll pay for the ride and promise to return. Please.
:cheers:
OK, true newbie question... I've not done axels yet, but its on the list.
What is an SST?
It's an easy tool to make. Start with a very large socket, about the same size as the lock ring, and grind 3 slots in the rim to accomodate the 3 protrusions on the lock ring. Now you have a tool you can use with a socket wrench and torque wrench.
-Spike
:cheers:
Pm me, I just bought one, but haven't used it yet, cooling system issues have taken priority.
Cary
nakman said:
SST= special service tool
CJ if I had one you could borrow it man, sorry. need a front hub socket? :)
Thanks nak, i do have that socket allready. :cheers:
Where can I buy one? I'm not fully sure of what it looks like or does in order to build one.
Thanks!
Bear80 said:
Just so you guys know, the 4wheel drive socket for Dana 60/70 axle nuts will work. You can either buy it or use it as a loaner from AutoZone(my choice).
Good info, thanks. I'll give autozone a shot.
Thanks for the info in the SST tool substitute. A couple of weeks ago I was going to repack the rear wheel bearings, after reading that I needed the SST to set the preload I stopped. BTW, I love full floating axles! Much easier to work on than my mini truck axle! I want to swap a rear 80 axle for my rear mini axle.:)
Arya Ebrahimi said:
Alex, if you still need it, I've got one.
Thanks Ary. As of yesterday, the rear axle may be on hold until i can figure out and fix my front axle issue.
