Can anyone tell me a part number for these wire harness clips? (1 Viewer)
tincan45
Tulsa, OK
I'm trying to locate these wire loom clips? The old ones are brittle and falling apart. Any help would be appreciated.
Serviced with the engine wiring harness.
Except not at this time.
That one has a harness diameter of 1 inch. Hopefully it will work for you
Good point. It might be too large. I noticed these all have large numbers on them, I'm assuming this indicates size. The two I need are 15 and 13. 13 being the front so it's a bit smaller. It appears they were used on several Toyota models maybe even other manufactures in the 90's, perhaps I can get lucky with a little more digging.
Found the 15mm
Toyota Part Number: 82711-2A530 (08211-01520 15 MM Loom Clips)
Hopefully this will be helpful for someone else out there, I compiled a list of the known (to me) sizes of the wire clamps and the corresponding Toyota part numbers:
Metal Tab Clamps
7mm = 82711-24010
10mm = 82711-2A420
13mm = 82711-2A600
15mm = 82711-2A530
20mm? =
25mm = 82711-3H180
28mm = 82711-20870
I never got a visual confirmation on the 20mm. It would be great if someone could confirm.
The reference is confusing. Usually the diameter is called out. In this case it's "R". is that radius or a typo? Someboy's going to have to buy one and find out.
EDIT: It looks like you have that part number down twice. Once as 7mm and once as 20mm.
Screenshot 2023-03-30 at 13-28-50 82-02 WIRING & CLAMP diagram 07_2003 LEXUS LS430.png
Yes, thanks. I think it's safe to say the 24010 is the 7mm. I'm still not sure about the 20mm. I "think" the R is the radius outside of the ribbing. Best guess - the stamped number is the inner ribbing radius (smaller than the clamp radius)
It's too bad there isn't a "standard parts catalog" like GM has. One that lists fasteners and such. Toyota does that to a small degree with these clips, but only in model-specific catalogs. In many cases it shows retainers not serviced when a substitute exists. You have to think way outside the box to chase them down.
It's frustrating for sure.
Since I had the 25mm I'm not using I took some measurements. The diagram shows 26.7 whish is about right to the inside of the ribs. It's over 30mm to the outside of the ribs. My best guess would be the 25 is an indicator for the size loom in mm you want to clamp.
