Hello everyone,
New to the forums, long time Land Cruiser 100 series fan finally got my wish few weeks ago and bought a low millage 01 (64k miles).
I bought it knowing it was in minor fender bender and was fixed very well. I've been slowly fixing small items with the help of the forum (roof rack leak, antenna replacement, A/C floor leak, etc.) just things that seemed to have worn out from age not abuse.
Two days ago however I noticed that the left rear tire had some wear on the inside edge on otherwise brand new michellins. After further inspection I measured the distance between inside of the tire wall and the frame on the left tire and compared it to the right side and came up almost an inch difference.
In other words the driver side rear tire is 1" closer to the frame (measuring from the top) compared to the the passenger side rear tire.
I inspected everything with extreme prejudice and did not find any signs anything bent. The LC looks brand new from the bottom pretty much.
I know solid axles don't usually have camber adjustment and I don't think this is any different, at this point I'm clueless.
Could this be the bearings causing the tire to be at an angle? what else could cause this? I checked the obvious (tire pressure/load on truck)
Any help is appreciated.
