I'd appreciate some opinions from the knowledgeable folks on the forum.
It's a 2003 with the following suspension:
Having owned several 60/70 and 80 Series, this Hundy is my first IFS truck. And even though I like the confort and ride very much, I am having "height" issues due to (I believe?) the torsion bars.
It is not a matter of the IFS being stout enough or capable enough, which I believe it is for what I use this truck (DD and overland travel with the family. It does see it's fair share of off-road, and even though it will eventually go on some off-road park to some tougher stuff, it is not it's main purpose).
My beef with the Torsion Bars is that I have not been able to get what I consider a decent height at the front. I've seen lots and lots of pics of 100 Series on mud that seem to have a couple more inches than mine.
For reference, with an empty truck (no camping gear, full tank of gas) the measurement from the fender lip to the center hub is as follows:
So I'm wondering if there might me something wrong with these particular set of torsion bars, or maybe I should check something else on my truck (maybe I did something wrong during installation?)
I appreciate your help and comments!
Build thread here: 100 Series Build - Proper Family Hauler (but you can read on for a transcript and more detailed info)
I like the ride quality of the OME Heavy Shocks + TJM Springs. It feels just how I expected it to feel and perform. It is a harsher ride than normal, maybe too harsh for some people when the truck is unloaded? I'm used to it and I do not like soft "boat-feeling-style" suspensions. Besides, when the truck is loaded down with gear it is very plush and confortable.
The OME Torsion Bars OTHO I'm not satisfied with.
When I first installed the suspension kit, without a front bumper, the truck had a decent lift front and back. But when I put the front bumper and winch (one week later), the front came down. WAY down. It actually had the same clearance as it had with the OEM Torsion Bars (which I never cranked to get more height out of, since I installed the OME suspension one week after the larger tires). It was so low in fact, that I decided to take the winch out. It came up a little, but I still feel it is too low.
The torsion bars where installed correctly the first time, with the control arms totally extended to get the maximum height out of them and the adjusting bolt was un-screwed all the way out.
After I took out the winch, I decided to re-index them as I believe they settled a little (like any spring would do after a while) and I did manage to get some extra degrees out of them. (two notches to be exact)
But still, I do not have the height I want in the front. (Currently I DO NOT have a winch, I do not have a dual battery set up, and I have the Savannah Bumper without a chrome hoop, so I do not believe the front is too heavy).... For reference, if I wanted to fit 295 tires, they would NOT fit even for driving on the street (no off road).
I will try re-indexing the torsion bars one more time, maybe they have settled even more after the Big Bend trip... But if I don't get what I consider to be a decent height in the front, I'll look into replacing them with something else (a friend said that he once got a bad set of torsion bars and they where exchanged, but they where not OME, it was some other brand).
It will sit a little lower in the back once it get the drawer set and rear bumper... Maybe half an inch to one full inch lower? But I still believe the rake to be too much.
Here is a pic of the truck unloaded with a full tank of gas. NO winch.
- OME 60001 and 60003 Shocks
- OME Torsion Bars
- TJM 770RSHD80B Rear Springs. Why these and not OME Springs? I like them better as they are kind of "in the middle" between OME 864 and 863 regarding cargo capacity (harshness) but they are longer than the 864, so no spacer is needed. They are rated for a 440 pound constant (extra over oem) load.
- Slee Diff Drop Kit
- SPC Upper Control Arms
- FRONT: 20 inches
- REAR: 23 and 1/2 inches.
- FRONT: 20 inches
