SOLD California - 1999 UZJ100 257k with rear diff lock
Year
1999
  1. 100 Series
Mileage
257000
Color
Gray
Located in Arroyo Grande, California 93420, always lived in CA.
1999 Toyota Land Cruiser UZJ100 rear diff lock with 257k miles. Asking $12.4k. Runs as fine as the day we bought it, clean title, AC blows cold, rear AC/Heat control, third row seats, floor mats for all 3 rows, and wheel lock, extra sets of keys, service records, upgraded stereo with apple play, android auto and reverse cam. Rear diff lock, (light just flashes, read below), River Rock Green Mica 1C3.
Bought this back on March 11th 2010 with 70k miles from the second owner. This 100 series has been used as the wife's daily driver, and for family travel. With our first oil change we started using Mobil 1 synthetic with Toyota OEM filters every 7-10k miles. Dipstick always shows full even at time of oil change, so doesn’t burn oil.
Maintenance-
Engine Oil - Mobil 1 synthetic with OEM filters 90915-YZZD3, and fram air filter every 7-10k miles, since 2010 with OEM PCV valve
In cabin air filter TYC pt # 800099P2 added every spring, (as most know, Toyota will tell you its not possible but the 100 has the same slot as the LX)
ATF - drain/fill technique every few oil changes, (just pull drain plug and refill) usually took 4 qts.
Transfer case, F & R diffs - always changed together, only changed 3 times since ownership. Last changed August 2022 with 80W-90 GL5.
8/2011 Starter rebuilt with OEM parts, (plunger, contacts).
2/2014 127k OEM Timing belt / water pump / thermostat / drive belts / Camshaft and Crank seals / tensioner performed by San Luis Obispo Toyota
12/2015 Iridium spark plugs Denso (3297) SK20R11 replaced
12/2015 front and rear shocks replaced, (from PO Bilsteins), back to OEM Shocks.
9/2016 OEM Front and rear discs and pads replaced.
5/2018 OEM coil packs OEM Denso 6731303 x 8
5/2018 OEM fuel filter replaced
3/2019 210k miles - Brake M/C rebuilt OEM parts, and Brake Booster motor sent to Eurton for rebuild, (search on Mud for more info).
12/2019 Passenger side headlight replaced with OEM GLASS headlight
8/2020 234k mi. Timing belt / water pump / thermostat / drive belts / Camshaft and Crank seals / tensioner performed by Toyworx - Grover Beach, CA
8/2020 Radiator replaced with OEM Koyorad Radiator and new cap replaced with OEM
12/2020 PM - OEM Starter contacts, valve cover gaskets, along with valve cover bolts and spark plug gaskets.
6/2021 New Michelin LTX Defenders purchased at Americas Tire at 243k mi
8/2021 New rear rotor/drum/hub and shoes and pads replaced. New front OEM pads installed.
12/2021 PM - Starter rebuilt with OEM parts, (plunger, contacts). Valve cover gaskets, along with valve cover bolts and spark plug gaskets, All OEM parts.
8/2022 Fluid changed - front & rear diffs & transfer case 80W-90 GL-5. ATF drain & fill
The extras;
Toyota OEM rear view mirror with Homelink, to make the wifey’s life easier!
1/2021 installed a double din JVC KW-V66BT with Apple Carplay and Android Auto and back-up camera, (and yes, did it the right/difficult way; bypassed the factory amp. Read about it on mud!).
Interior domes and door lights all LED
The History;
First owner lived in Blackhawk, CA and put 40k mi on it from 99-07. Then they traded it in at Toyota of Walnut Creek, CA. The manager of sales snatched it up for his personal vehicle and put 30k miles on it. I believe other than normal services, they had also serviced front brakes and replaced shocks with Bilsteins.
The Bad;
Rear Diff lock light just flashes when turned on. (Lot’s of write-ups on how to fix here on mud). Rear driver corner bumper backed into object ~8 years ago, superficial damage only (look at pictures). Clear coat starting to go on the horizontal surfaces, (see pictures). I unplugged the power to rear wiper years ago, it was running with front wiper.
Let me know if you want additional pics or have any questions.
Asking $12,400 or best offer.
Rear cargo area: carpet, landcruiser floor mat and all weather mat
