Flint is on to something here. Most folks think that if you have a good SWR, that you're golden. Truth is, there are other, measureable factors that effect the radiation pattern, and overall efficiency of any transmitting antenna.
One of the easiest inhancements is to make sure you have a good RF ground. RF ground is not DC ground, because RF voltage has considerably different characteristics than DC voltage. Simply because there is continuity (as measured by a meter) between the mount and ground, doesn't mean you have a good RF ground.
The further away from the body your mount is (as in on the bumper), the poorer an RF ground you will have. The solution is to run a wide (1/2" is usually ok) ground strap between the base of the antenna and the mount it is attached to.
Then (if you are mounted to the bumper), run another ground strap between the bumper to the frame, and yet another from the frame to the body of the truck. This way you have a high current path to the body, even if you are not actually mounting your antenna to it.
In the image, you can see the strap between the base of the antenna and the hatch. There is another (hidden) strap between the hatch and the body itself.
You might be surprised how much more efficient an antenna can be when grounded this way.
BTW, properly soldered terminals are essential here; crimping alone is insufficient.
Cheers, R -
