Last night I sat down with the FSM and spent some quality time reading the engine section. Was looking for an oil pressure take off and return spot for a bypass oil filter. The best I can come up with is to T off the "oil pressure switch" at the oil cooler and return to a drain plug taped for a banjo fitting. Is this oil pressure switch Toyota speak for pressure sending unit or is it an actual switch and the sending unit is seperate ? If its a sending unit I don't mind feeding a bypass filter at this point. If its a low oil pressure switch I would rather not induce the time delay into what ever system is being switched. Any feedback from the guru's
Now the rambling part... holy crap are these engines well designed. I am a mechanical engineer by trade, a weekend wrench by choice, and grew up on a farm taking apart everything from 5 HP briggs and stratons to 1150 CI Cummins engines. I have never seen another gas motor that has 6 combinations of select fit pistons on the production line, not to mention piston oil cooling jets. Some diesels out there don't have piston oil cooling... Keeps your 80's boys they don't get any better.
