I'm in the planning stage of my build and would like opinions on running with an independent front suspension. First off; I am not building a Toyota but it will have Toyota parts. My rig is a '81 Datsun 720 KC. I plan on keeping the IFS so I'm here seeking wisdom. I know that there are Nissan forums out there but I've been reading a lot of the threads here and I am very impressed with the builds that I have seen.
I'll be running a 4.3 GM with a TBI and a 700r4 trans and I would like to go with a Toyota rear. My truck has 4.36 gears and from I have read, the early Toyotas ran a 4.37. I'd like to run the Toy rear because it would be a lot cheaper to find a locker and a disc brake conversion for it than the stock Datsun. Do you think that the 8 inch Toy rear will stand up to the 4.3? I'll be checking out the tech forums to set it up.
The engine will stay pretty muck stock and I plan on running with 235/75 tires. I'm also building camper top for the truck with on-board water. I'll be cramming as much as I can into the cab and bed for now, but once the truck is up and running, I want to build a small off-road teardrop to pull behind it.
My plans for the rig are to run some decent trails that will get me away from civilization for some extended periods of time. Trips will depend on how much time I can stay away from home and still be married when I get back. I'm the only one in the family that enjoys this stuff so it will be me and the Catahoula.
Any tips or advice would be greatly appreciated. Thanks.
