Broken valve cover bolt
Landman2000
Ringgold, GA
Hey guys,
Replacing valve cover gaskets today and the very back drivers side bolt (hardest one to get to) broke. I noticed it was tight and sprayed it with PB Blaster. I thought it was turning but the head snapped off. I tried getting it with some vise grips clamped on tight but there is not much room to work. I would really like to avoid breaking it off flush.
Any input on the best way to get this out?
Heat the remaining piece of bolt that is stuck into the cylinder head.
Went ahead and purchased some of these. Did some research and they look to be pretty high-quality. Won’t have them until Wednesday though.
Hope they do the trick.
I had the same one break on mine. I was able to drill it out using right angle attachments, etc, but it was next to impossible because of lack of work room. A few months ago I replaced my master cylinder booster unit and when I had it out I was amazed at how much easier it would have been to drill out that broken bolt without the MC in the way, a straight shot in with a drill! You can get the master cylinder unit out in about a half an hour and if it ever happened to me again I would deffinetely go that route.
Good luck!
Heating it, either with a torch or induction, is going to help a ton. If you can't get it to break loose, one option is to drill it out completely and replace with a through-bolt and nut. As mentioned above, if you remove the brake master there's a lot more room to work.
Good luck!
Good to hear. I have some extractors coming tomorrow. They are my last resort before drilling. I’ve tried welding nuts on but they just kept twisting off along with a little of the bolt each time. I preheated the heck out of the area too..This puppy is seized. I do have a Milwaukee M12 right angle drill. If it comes to that I’ll drill the bolt out and retap with a 6mm tap. If that doesn't work I’ll through bolt it. I’ve heard you need a scanner to properly bleed the brake system if you remove the master cylinder. If thats not true. I’d definitely consider going that route.
Welding nut on stud, is the best way to go.
I tried several times. Each time the nut would twist off with a little more of the stud. Good weld and I heated the area real good too. I’m down to about a 1/2” stud now. This thing is seized. If the extractors I have coming tomorrow, don’t work. It looks like I’ll be drilling.
I had this happen on exhaust flange bolts (break off every time I welded on a nut and applied torque). This happened on both of the bolts *until* the bolts broke off slightly below the surface. The next bolt (actually a thick flat washer followed by a bolt), the broken bolts came out in one piece. These bolts were so hard from the heat cycles that I could not drill into them. It seemed like there was something about getting past the surface that allowed them to finally come out. After this I just ran a tap through them and installed new studs.
A good low profile metric stud puller is another option. Not the universal ones, but the size specific.
I have some of those coming tomorrow not real low profile, but they are high-quality and size specific.
I really don’t think it’s going to do anything but break off flush so I’ve come up with another option I think will work.
I have about a 3/8-1/2” of stud remaining that I was able to clean up with a 6 mm Die. I found these T nuts at Ace Hardware and threaded one over an old valve cover bolt along with a flange nut and welded them together. I gave it a trial run without a valve cover gasket and it seemed like it will work. The T nut fits perfectly into the valve cover hole and catches the remaining stud.
My only concern is the strength of the T nut threads.. The nut welded on top is just for the socket. My gut tells me it will be fine. If not, I just gotta pull it back off and start over.
What do you guys think?
