So here is the rundown- having trouble figuring this out- need help.
Bright lights do not work. I turned them on the other day and noticed "something". It wasn't exactly a flash but when they went on it's like they turned on then immediately off.
When low beams are on and I hit the brights- the fog lamps turn off but no brights.
No daytime running lamps either.
I did just install fog lamps and was trying to change the switch for that (installed lower left cluster) but wasn't able to replace and I put everything back and closed (not sure if connected but mention it anyway).
Checked the fuses under the hood (I think #55)- seems ok.
Any idea for other tests I can run?
