- Joined
- Sep 9, 2004
- Threads
- 184
- Messages
- 13,061
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
So knuckles from a Hilux will bolt on a 70-series HP 8" front axle. FJ60 knuckles will bolt on a pre-90 front axle and I believe the Hilux will as well.
I can go to any auto parts store and buy remanned FJ60 front brake calipers for $40. I have a set of brand new FJ60 remanned calipers in hand for another project and without even comparing I know they are not exactly the same as the 70-series HP 8" calipers. I have not checked close enough to see if they will work or bolt on. Has anybody checked into this? Part numbers are not the same.
On this note, are Hilux calipers the same as 70-series? I ask because if the FJ60's won't work the Hilux may very well work.
The point of this post is to find out for sure. This allows people, myself included, to walk into any auto parts store and buy reman calipers for $40 rather than buy them front Toyota at $250-400 each.
Besides calipers what else may bolt up? The knuckles do so a lot of other stuff available here in the states should also. Spindles? Hubs? What else? I am well aware spline count on shafts matters here.
Here is where I am going with this.
Chromoly spindles are readily available here. High steer kits too. Backing plate eliminators. Rock rings for the back of the knuckles and more from a Hilux or FJ60 can be bolted on a 70-series.
Cheers
Cheers
