- Joined
- Sep 9, 2004
- Threads
- 184
- Messages
- 13,061
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #21
In a nutshell those HD 7x 8” HP axles use several parts that can be sourced/exchanged from other cruisers but you can’t simply remove the complete knuckle/ hub assembly and mount it on any other Toyota axle or do like a disc brake conversion with them on a 40 series or so. I wish the opposite was tru because I have always fresh inventory of these.
Here is the problem I have with your statement. Just like I said above, I have done it.
While in Latin America with my PZJ70 and while rebuilding the front end I discovered the brake caliper mounting holes were stripped out. I checked with Toyota and no new knuckles were available in the country. I talk to my good friend who is in the local 4wd club and he tells me Hilux will work. He also says the guy who owns the big fab shop in town for the 4wd club has a used set of Hilux knuckles and will bring them over. I have no idea if these were LN106/07 knuckles because I never asked, I suspect they were and for those that don't know the LN106/07 is a non-USA spec Hilux with a SFA made from about 1990-97.
I go to put the Hilux knuckles on my truck, I already had the new Cruiser trunnion bearing race set in the knuckle ball, and it won't clear. What it is hitting it the race, only the race for the trunnion. It is a very small amount that is not allowing it to clear, like I have mentioned before in this thread, a mm or less. I talk to the guy who supplied these and say, hey these won't work. He says yes they will and before I say why he already knew it was a prob with the trunnion, so he suggests to just grind it a little bit or use the Hilux trunnion bearing. Not wanting to grind it, which by the way Georg and I have discussed grinding to fit these Hilux knuckles, I asked if he had some old Hilux races laying around so I could try it. He said yes, gave me some and I proceeded to bolt on the knuckle. I only used the Hilux races, it was for test fitting purposes. The Hilux race and bearing is slightly shorter than the Cruiser, IE the Cruiser runs a slightly larger trunninon bearing but not larger in diameter, it is taller or as I said above more "proud". I didn't have a set of calipers to measure any of this nor was I trying to figure this out in terms of if I could use Hilux knuckles in the future or whatever, I was simply trying to put it back together. During the rebuild process but before I was done I noticed the caliper mounting holes on these replacement knuckles were not 100% too. They were not as bad as mine but one hole was compromised and another was not so great. At the same time I found new knuckles for my truck in the Middle East online for just under $150/each. I decided to just slap it back together with my old knuckles and order those or deal with the issue once back up here in the USA. Getting the right tap down there or more importantly the right grade bolt was not happening so I didn't want to deal with drilling and tapping down there. So before I installed the knuckle wiper kit on the back of the knuckle or for that matter the spindle I pulled them off, gave them back to the guy I got them from and got my $100 back and put my old ones back on.
So @joekatana you are telling me I didn't do something I did. It is also hard for me to take your info on faith alone since you have been wrong before, such as when you told the Aussies on Facebook there is no such thing as an HDJ78 and you rudely said they should go do their research before posting on the internet. Man you sure were wrong about those HDJ78's! I even knew there was such as thing as an HDJ78 since I have spent hundreds of hours combing through parts books for all 70-series models. As you have happily pointed out a number of times in my threads, I am a newbie to 70's which is either you trying to prove you know better and are right or you trying to discredit me or both. It is condescending, rude and disrespectful as well as arrogant to communicate this way. I am all for the wealth of knowledge you have and that knowledge being shared but I don't consider you to be the guru of 70-series.
Any ways, I think it is obvious what I was trying to figure out here in this thread. I replaced my knuckles a few months ago with new OEM ones. I tossed the old ones or I could compare to the 60-series knuckles I have sitting here. Bolting up the Hilux knuckles is not really what I am trying to show can be done here. Rather, do Hilux or other brake calipers work on a 70? Is the outer axle the same so a person can use things like chromoly spindles readily available here in the USA? That is the whole point of the thread and info I was trying to figure out.
Cheers
