Hi all, I’ve got a 73 drum brake fj. I just changed master cylinder brake lines wheel cylinders yadayadayada . Well in doing all that I’ve come across an interesting situation. My truck has been running a little funky at higher rpms I pull out rhe choke while at those rpms and she runs much better. So since I was doing the brakes I decided to run a test. I unplug the brake booster and drive it and that cures the issue at higher rpm. Plug it back in and problem returns. I don’t have any issues with my braking system what so ever. No classic signs of bad booster.. I sprayed countless cans of carb cleaner at the intake carb and brake booster check valve grommet. No signs of air leak..... and the truck runs great at idle , just that higher rpm. So is this a sign of a leaking brake booster? Only at higher rpms? Thanks in advance
Edit: if this is a sign of bad booster, can I replace with something newer(4Runner, minintruck booster)?
