Here's my brake situation:
New stuff in rear, put self-bleeder screws all around and on LSPV. I've bleed and bleed and bleed some more (4 quarts now and have been doing it per instructions on previous threads)...and I'm still getting little bubbles from the LSPV (no bubbles on any of the calipers).
Now I'm thinking the brake booster has gone bad, here's the situation:
When I press on the pedal with the engine off, there is no change in the pedal, all is good. However, when I press on the brake pedal and start the engine, the pedal goes all the way down or close to the bottom quickly.
After the engine has been running for a couple of minutes and shut it off and then press on the brake several times, the pedal gradually rises and feels solid at the top. But, when I press on the brake while the engine is running and stop the engine with the brake pressed down it pops back up.
It's wierd, I have some of the symptoms of a bad brake booster, but not all of them. Makes me wonder the following:
Why do I have some symptoms, but not all?
Does the brake booster need to be replaced or I'm I missing something?
How do you know when the master cylinder needs to be replaced?
Does the LSPV ever go bad? How can you tell?
Is the issue with my self bleeding screws?
Any advice is greatly appreciated. Thanks.
